Question about Refrigerators
Open door alarm going off but doors are shut on my JI4307335 fridge
  • 725 Answers
Shorted door switch / wire to door switch / or control
Posted on Apr 05, 2008
SOURCE:
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
Temp alarm went off on my Electrolux Full Fridge. Indicating 27 degrees Middle of the night Power didn't go off Door well shut. When I shut off alarm fridge seemed cold. But condensation is there.
I appreciate your inquiry, KC!
Based off what you have described your Electrolux refrigerator has condensation on the inside of it. This could be a possible issue with the door being left open or the gasket could be bad. You can check the gasket by using a dollar bill. Please the dollar bill between the refrigerator and the door. Pull the dollar bill, if it provides resistance then the gasket is good. If the bill comes out with no resistance then you may need to replace the gasket. I hope this information is helpful to you. -Matt
Apr 11, 2015 | Electrolux Refrigerators
How can I turn the door alarm off in my samsung fridge?
the alarm indicate that the door is open
check the door switch and check if the door press the switch or not
I think the door latch didn't reach the switch
Jun 07, 2014 | Samsung RS2630WW Side by Side Refrigerator
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Miele fridge keeps beeping
Door is open (shut it)
or
seal on door is broken ( replace it)
or
temperature dropped too low ( reduce it)
or
door was lett open too long (reset alarm)
- after ffix
press alarm buttons once to switch of beeps
Oct 20, 2013 | Miele KFN8862SD Bottom Freezer...
GE GSS25WGMC door open alarm beeps and both doors are OK and seal properly
check to make sure in fridge and freezer there are switches when the door make contact with it it shuts off the lights-check by hand by holding the swiches down and see if the interior lights go off, if not then you have a bad switch..if they go off then the control where the door alarm is located needs to be replaced
Oct 01, 2011 | Refrigerators
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
608 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
