Question about Car Audio & Video
On my 405 a light has appeared on my dash board it looks like a radiator or a alternator warning light
  • 185 Answers
Then go to auto zone have them check it out
Posted on Apr 05, 2008
SOURCE:
Red battery appears on my dash board?
Polimar, Posted links to tell and show you why battery warning light may be on. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford Battery Warning Light What it means Checking It
How to Test an Alternator
How to Test Car Battery with Multimeter
Jul 04, 2016 | 2006 Ford Escape Limited
Peugeot 406 - orange car shape come up on dash board as a warning light just above oil pressure gauge. What does it mean please ?
check engine light..an auto parts store have hand held scanners and can tell you the problem for free... Hope this helps tim
Aug 29, 2010 | 2005 Peugeot 405
I have a red warning light coming on in my peugoet
Its the low water warning light. You need to top up your radiator, or check for leaks.
May 04, 2010 | 1991 Peugeot 405
A orange light is on in the dash board it looks like an alternater
The alternator light is red. An orange light is a warning. This could be the engine check light.
Mar 04, 2010 | 2002 Ford SVT Focus
MEANING OF DASH BOARD WARNING LIGHTS
Hello If it looks like a battery then most probably one of two things. 1- You have a bad battery. 2- You have a weak alternator that is not functioning properly and can not keep up with the car needs. You should check the alternator charging value and then check the battery. You could do that at any shop that has the Battery/Alternator testing tool. Hope that helps
Jun 14, 2009 | 1998 Mercedes-Benz C-Class
1990 Peugeot warning light
Well i had same proplem and it is that it could be your radater is leaking or the rubber pipe to the radater is split and leaking from that. Or your cooler as got an hole in it and that is at the back off radater which as only got two pipes from it. so put some water or coolent in it and see if it is leaking that way by running the car around the block and then see if it leaks that way.
Mar 28, 2009 | 1990 Peugeot 405
Alternator?
start the car and take the pos cable off the vattery,,,if it fies your alternator is no good.
Aug 15, 2008 | 1992 Lexus Sc 300
1997 toyota 4-runner, My battery dash light is on. The battery is good.
The battery light on at the dash indicates a problem internal in the alternator. Normally, when the alternator is producing sufficient voltage (14.4 VDC), the light stays off. When the alternator is NOT producing sufficient voltage, the light comes on. Check the voltage at the battery with a voltmenter with the engine running. If you have less than 12 volts, you both need an alternator.
Aug 09, 2008 | 1996 Toyota 4Runner
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
