Question about Danby DDW496W Free-Standing Dishwasher
Danby DDW496W Leaking Brand new
Hello. I have a brand new Danby DDW496W. I checked all of the hoses and it seems when this washer drains, it is leaking from the bottom. The water appears to drip slowly from the screws at the bottom. Everything seems to be level. It is not dripping as much as it was ever since I hooked it up again however there is still some noticable dripping sounds coming from it.
  • jboulley37 Mar 13, 2009
    it leaks from the front bottom of door and from sum of the holes at the bottom.
  • 142 Answers
Check your hose connections in the back for tightness and sealing (there should be some rubber seals inside the screw-in connections) and if tight and not leaking, you might have a loose clamp inside the unit, or a leaking/damaged hose, or even a defective/leaking pump. If it is brand new and returnable I'd return it for a new one rather than try to fix it...
Posted on Apr 10, 2008
Check the internal window, the rivits holding it in place broke on mine and it caused it to leak :(
hope this helps
Posted on Sep 10, 2008
Danby washing macine is leaking
Hi There,
I have just spoken to a technician here at Danby and he suggested to replace the washer in the hose.
If that doesn't work, please feel free to contact our customer service department at 1-800-26-DANBY (1-800-263-2629)
Jun 19, 2012 | Danby DWM99W Top Load Washer
Danby ddw496w
Maybe you have the wrong part , contact danby and ask a replacement
Apr 07, 2008 | Danby DDW496W Free-Standing Dishwasher
I have a danby ddw496w that leaks water from the bottom of the machine when it goes into the drain cycle.it will start coming out the bottom as well as the drain outlet .Could it be a simple hose...
Ditto- same issue, hoses are tight, just leaks through the bottom while draining. Anyone with advice? I just bought mine used, and the previous owner is willing to buy a replacement part, we just have to figure out what we need...
Sep 25, 2011 | Danby DDW496W Free-Standing Dishwasher
Brand new beko DE 2542 PW dishwasher won't start wash cycle
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
May 09, 2010 | Dishwashers
New inglis washer expells water when fills
seems like no one wants to send you any love Richard. Well fear not, if you haven't figured this out yet, I'll do what I can. It seems to me that you have the drain hose lower than the top of the wash basket or a hole in that hose. If the drain hose is too low, the water will run out of the machine due to low center of gravity. Ideally, 6" above the level of the tub is sufficient. If there is a hole in that hose, replacement is pretty straight forward.
Jul 18, 2009 | Whirlpool Inglis IP4400 Washer
Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
Danby ddw496w
Havent solved it yet. Have to call the Danby 1800 number to see what I need to do.
Danby DDW496W Free-Standing Dishwasher Logo
550 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
