Question about EZQuest Cobra Plus (B66600) 80 GB Hard Drive
Power Supply Board needed for EZQuest Cobra Plus 80 GB Hard
A friend gave me this drive stating that the HDD just clicks when powered on and will not startup. I found out that I need to get a replacement power supply for the unit. It has a burned transistor and capacitor on the power supply board. It looks like somebody spilled something on the drive
  • 1 more comment
  • Anonymous Apr 05, 2008
    Thank you pagebor.
    My goof.. I know I need to change the power supply. I just need to know where I can get a replacement power supply.
  • oG_HaZe Apr 06, 2008
    I HAVE A FIREWIRE AND IT USE TO WORK BUT WHEN I CONNECT IT. IT DOSENT WORK???
  • Anonymous Jan 09, 2009
    i have the same problem with my EZQuest 250GB hard drive , any body know were to find parts?
    Genius:
  • 2,785 Answers
Please change the power supply
Posted on Apr 05, 2008
SOURCE:
I want to reuse an ezquest cobra 250 gig external drive for time machine on a G5 powermac. the drive has files on it which are locked down. I want to wipe the drive and use it for back up. can this be...
Go to your applications folder and then to the utilities folder, find the application disk utility and then double click on it. Select your hard drive on the left hand column and then click on the erase button and select the format you require for the drive. Usually for a mac only backup you would use the format of Mac OS extended (journaled) or if you want to use the drive for mac and PC use the MS-DOS (Fat) option then click erase. Hope this helps.
Aug 05, 2011 | EZQuest Cobra USBII 250 GB USB 20 Hard...
Makes "clicking" noise and will not mount
that is a common noise when your HD just failed it can be internal or external most of them work the same way, there is 2 metal readers that hover on top of the actual disks to read the information. Those readers get stuck or keep going back and forward trying to read (that is the clicking noise) a way to try to fix the problem (it works sometimes) is replacing the circuit board attached to the hard drive (inside the metal enclosure) and you have to find one with the same characteristics as the one you have now. sometimes when we really need to recover the information we try that and it may, may not work
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | EZQuest Cobra Plus (B12660) 120 GB Hard...
The HDD is in a Mobile Disk external package. The external power supply is dead. I need the specs for a power supply ( voltage, current).
This will resolve your issue,
http://www.samsung.com/ph/consumer/monitor-peripherals-printer/hard-disk-drive/35-pata-hdd/SP0802N/index.idx?pagetype=prd_detail&tab=spec&fullspec=F
please remember to vote right if my recommendation resolves your problem,
regards
Mar 24, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
MY IOMEGA HDD 80GB KEEPS CLICKING AND NOT CONNECTING TO THE PC. wHAT IS THE PROBLEM?
There can be several causes for the clicking noise. Your disk drive may not be getting enough power or the drive may have failed. If you have an external power supply for the drive, make sure it is connected to power and it didn't fall out of the outlet. If you can try another USB port on your (or another) computer, try it. If the drive fails to mount on another computer with the disk's power supply connected to power, the power supply for the disk or the disk itself may have failed. If you have an identical power supply from an identical drive, you can see if that isolates the problem. Please post back with results of your tests.
Aug 15, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Wont mount
Hello there
if the unit wont mount contact a local repair shop and ask them if they have a universal kit for the harddrive so it will fit into the bay ok
Aug 05, 2009 | EZQuest Cobra Plus (B12660) 120 GB Hard...
The mini-USB connector has broken loose. Verbatium provides "ZERO" assistance, as they do not provide replacemnt cases or internal parts aside from replacing a failed HDD. I am looking for a internal power...
Alternatively you may be able to resolder the USB port, maybe an electronics savy friend with a soldering iron will help you with this. If you want somebody else to do it for you there is Data Recovery NYC. Also there is good informaation on logic board repairs on hddguru.com.
Jul 01, 2009 | SmartDisk FireLite 80 GB Hard Drive
Drive wont show on desktop
Have you tried going to "My computer" and looking for the drives in there? If they are not there then you might have problems
Apr 22, 2009 | EZQuest Cobra Plus (B12660) 120 GB Hard...
Hard disk can not detect and giving beep randomly. hard diisk is from seagate and capacity is 80 gb
Hello there..i have experience with same problem like this...there is two problem with hardisk: first with the mechanic platter inside your hardisk ( you can hear noisy sound from inside HDD) 'cause by wrong prosedure when turn off the pc or problem with chipset on hardisk board (you can see the small green pcb board at other side of your hard disk) touch that board...if feel hot yes there is problem.this problem cause by electrical shock from your power supply unit or you not plugin correctly to hdd power socket.
solution for first problem :
send it to nearest seagate 'cause they have all the parts that you need
solution for second problem:
replacle the board with same tipe and size of your hdd..and it will work again and you can safe your data.but if not...nothing you can do it
Best Regrad
SHOGUN 125
Jan 21, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Front light jumper cable
If it has the black and red wires, it connects into JP2.  The other wires, which are black and green connect directly to the power supply into connector CN4. Bob
Apr 04, 2008 | EZQuest Cobra Plus (B66600) 80 GB Hard...
Hardware recognition
to ba able to recognize the device you must secure that the connections between the hhd and cables to other device must be properly and in tact.
if it doenst recognize it, restart your computer withour removing the device and youll see the computer recognize it.
Feb 05, 2008 | EZQuest Cobra Plus (B12660) 120 GB Hard...
Open Questions:
See all EZQuest Cobra Plus (B66600) 80 GB Hard Drive Questions
EZQuest Cobra Plus (B66600) 80 GB Hard Drive Logo
234 people viewed this question
Top EZQuest Computers & Internet Experts
Ekse
Alun Cox
Are you an EZQuest Computer and Internet Expert? Answer questions, earn points and help others
