Question about Bosch WFR 145 Front Load Washer
Rubber sean and wire spring came off
When I opened the door to my washer the rubber sean was loose and the metal ring and spring were off. How do I re-attach them. Seal is not a problem, but the metal ring is. First, at what position does the spring go. i.e. 6 o'clock or 12 o'clock? Is there a trick to putting it back on? When I try to stretch the spring, it pulls loose from another location.
  • 725 Answers
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Posted on Apr 05, 2008
  • Bosch Master
  • 744 Answers
Bosch WFR 145 Front Load Washerhow
to get the seal,metal ring and spring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
SOURCE:
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Rubber door seal came off along with metal ring. How do we fix it?
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 30, 2009 | Washing Machines
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Jun 30, 2009 | GE Energy Star WCVH6260F Front Load Washer
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch WFR 145 Front Load Washer Logo
474 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
