Question about JVC AV-65WP74 Rear Projection Television
I change that part but
I haven't been able to fix the convergence , specially the blue one , i got almost fix red and green ..
i think i move some numbers on convergence 6 and 7 on main set up !!!
how can fix only the blue ,or how can i fix that convergence problem ...
thanks
How do i move the number in the main meau
Posted on Jun 08, 2008
Changed ICs Chips but still got bad convergence
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Details of this adjustments are given.
May 01, 2017 | Philips 60PP9202 60" Rear Projection...
I think i have a convergence problem with my 57f 500 tv it looks like 3d i went into the magic focus and did the manual thing and it seems like the only one that i cant get lined up is the red looks...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 01, 2011 | Hitachi 57F500 57" Rear Projection...
I can only adjust the red and blue convergenge, the green just sits off to the side and is a little crooked. any fixes?
You should only be able to adjust the red and blue guns. The green beam is fixed and should be located over or between the red and blue beams. The goal is to adjust the beams to converge and become a white light.
Without seeing your unit it is hard to tell exactly what it is doing. Because the beams are moving you probably do not have a problem with the digital convergence ICs but you certainly could have a problem with the digital convergence box. They are no longer available but can be repaired at http://www.moduslinkptstvboards.com . The part number is 23781985. Cost to repair $120.00 US. If the digital convergence board does not fix your unit you will need to try adjusting the ring magnets on the green CRT.
If the green is not between the red and blue I would adjust the center magnets on the green to move the green beam where it should be. Before moving anything note where the settings are now and write them down. The adjustment would need to be done with the set live which presents a shock hazard for a non technician. If you do not feel comfortable with the adjustment you should hire a technician to do this.
Thank you for using FixYa and for the great rating.
hardrocko
Oct 25, 2010 | Toshiba TZ43V61 43" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Thanks alot for yhe info ...I have a Hitchi Model# 51F500A and it looks 3D mostly the red is ghosting and I hope the convergence kit I order will help...Is there anything else that would cause this...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2010 | Hitachi 51F500 51" Rear Projection...
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem with samsung sp42w5hfx
Hi.
Post your email address & I will send convergence set up manual.
http://dysonmanuals.inc.io/
Chris..
Nov 04, 2007 | Televison & Video
JVC AV-65WP74 Rear Projection Television Logo
124 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
