Question about Cdt Audio CL-51 Car Component System
CL-51 Braxial component
Just had body work done on right front door, and now my bass on the CL-51 seems to get static noise when turned up. Never had problem before. Could the taking out the speaker and putting back in have caused the problem? Could the bass be blown or possible grounding on the speaker? Tweeter sounds fine.
  • 185 Answers
Ok well do u have a amp hooked up on the speaker and if not u could have dust in there or it could be a blown voice coil in the woofer part it self best way to check is to take a cotton swab u use in ur ear andgo along the coil part the speaker u no the brownish looks like ornge wires sum thing like that and do it very gently swab around the coil let me no if that helps
Posted on Apr 05, 2008
SOURCE:
DLG2351r model LG front load dryer wont start also says CL
It seems as though your machine's door switch is faulty as the machine will not start if this switch does not operate properly.
The reason that I suspect the door switch is because the CL error code stands for "child lock".
Check the door switch for continuity and condition, replace if faulty.
Oct 03, 2014 | LG Dryers
Long beeps at start up
Indicates problem with Ram Memory.
Computer on a table, computer unplugged from power, FOLLOW Anti-Static Precautions.
Remove all Ram Memory modules, ("Stick'), clean the gold plated contact pins with an eraser.
If you use an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub up, and down on EACH contact pin, BOTH sides. Doesn't take much pressure, or rubbing.
In fact when you are done it may seem like you have done nothing at all.
The contact pins may not be bright, and shiny. I assure you that you have cleaned them. Doesn't take much 'corrosion' to make a bad contact surface.
Use air to remove the eraser dust. You can use a can of compressed air for computers if available, or air pressure from your mouth will be sufficient.
Reinstall all Ram Memory modules.
Handle the Ram Memory modules by the BODY.
The Body is everywhere on the Ram Memory module EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 18, 2012 | AOpen MX3L (91.88110.251) Motherboard
Hi, our RXV465 was working great until a few weeks ago. We were watching a movie, and all of a sudden the movie sound switched to radio static. No errors were shown on the display, and we have gone...
According to your description, there is the high possibility that the button for one of your audio calibrations was pressed on the remote. Frequently referred to on many models as 'level', pressing this button will enable a built in test signal called wide band pink noise, sounding exactly like radio frequency noise. Pressing it again or repeatedly will resolve the problem.
However, if what you are experiencing is not just a pure static-like tone but also your intended audio with it, then it is a different problem that the root cause of may not be in the receiver.
Aug 24, 2011 | Yamaha RXV465 51 Channels Receiver
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Hi, I just installed an EMG P/J along with a Bass Treble System. I feel sure that I followed the schematic right. My problem is the front PU doesn't work. The balance control has a static kind of noise...
Without the instrument, and assuming all connections are solid parts are new I'm gonna guess low battery voltage. That's my guess because a bad 9V can cause things to freakout, and Sam - that Pbass is freaking out.
Dec 18, 2017 | EMG BTC-SYS Bass/Treble System w/Blend and...
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Speakers stopped working.
More than likely you have blown outputs, as the sound you hear when you touch the leads to the terminals is the DC offset of the power supply being routed through your speakers...accordianman
Jun 09, 2008 | Aiwa AV-DV75
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Mar 29, 2008 | LG WM-12230FB Front Load Washer
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Cdt Audio CL-51 Car Component System Logo
Top Cdt Audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Cdt Audio Car Audio and Video Expert? Answer questions, earn points and help others
