Help I need a code for a Diamond Vision television using a OAF Kameleon 6-Device Hybrid Remote
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
What code to use for my diamond vision tv.
Hello
The universal remote codes for Diamond Vison Tv are:
0210 0948 0092
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
May 21, 2011 | Televison & Video
Diamond Vision TV Code
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Diamond Vision TV/DVD combos in the One For All URC-3021 Code List.
But don't give up; many manufacturer's re-use others' control codes. Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual
One For All URC-3021 Code Entry
One For All URC-3021 Reassign Key
May 23, 2010 | One For All URC-3021 Remote Control
Sanyo tv,RCA universal remote,Diamond Vision player--compatible?
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
Jan 12, 2009 | RCA 3-Device Universal Remote with...
Diamond Vision DVD Player 803-04
call number of back of manuel and they can sent you one for 12. If you need number you can message me or look it up,
Jul 06, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Tv code
The brand of the remote please.
May 08, 2008 | Televison & Video
Diamond Vision Progressive Scan DVD Player
The only Diamond Vision Codes I can find are these.
Hope one works for you.
0622, 0496, 0810
Have a nice day!
Feb 24, 2008 | Televison & Video
Electrograph Plasma TV
you could buy an all for one remote control. i bought the kameleon 6 for 1 and its very easy to programme. just put in one of the codes supplied in the book for the brand of tv you have, once youve put in right code there should be no problem setting up the tv. The best place ive seen for the kameleon remotes is ebay, very cheap compared to what i payed. hope this helps
Feb 09, 2008 | Electrograph Systems DTS42PT 42 in....
Tv/dvd
Try ordrer the original remote contrl by Tv's manufactory. Aleixo
Sep 04, 2007 | Toshiba MD20FM1 20 in. TV/DVD Combo
Code for universal remote
This must be a duplicate post. And because I'm not sure which one you'll check I'll just post the answer here too... Diamond vision is a little pickey with handing out their code access. And Rogers doesn't have a whole lot about accessing components like DVD players. But try this: 1. Turn on DVD player 2. Press the AUX button at the top of the remote 3. Press and hold the SETUP button until the LED light blinks twice. 4. Press 9-1-1 in sequence, the LED will blink twice again. 5.Aim the remote at the DVD player and slowly alternate pressing POWER and AUX. Stop when DVD turns off. 6. Press SETUP to lock the code in memory. It may take several minutes of alternating between POWER and AUX to find the appropriate code - be patient... If after ten minutes you haven't got it try programming it as a VCR - steps 1 through 6 above and substitute VCR for AUX.. Good Luck Bill
Jun 10, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Code for remote / Diamond Vision DVD Player model: DVD807-04
I found the code! It is 0736. The company is now called AudioLogic.
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
