Question about Gateway 3250X Media Center PC Desktop
I unplug the power led, power sw and HHD led
I unplug the power led, power sw and hdd led this are little plugs on the mother board need to know how they went back on or what order
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Gateway's support site should have a nice diagram for you in your manual--they are also quite helpful if you have trouble locating it.
Posted on Apr 05, 2008
Power sw reset sw power led hdd led where is located in the mother board intel e 210882?
Hi Dear
For the installation the new motherboard in you PC, click here and find the guide book for mother board installation.
God luck
Sep 08, 2011 | Intel Motherboard
I need to know where to plug in my power cables on the mother board i have 5 cables that need plugged in One is RESET SW, POWER SW, HDD LED, + P LED, and - P LED can you possibly give me a picture pointing...
Can you go to the MSI website and download the manual, looking at your motherboard usually it can be found at the bottom of the motherboard, usually the right side, also you should see small abbreviations of the connection relative to the pins they are associated to. If you need more help just ask. Thanks Rick.
Jul 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Need to reconnect (Power LED, Power SW, H.H.D LED) wires for eMachines MotherBoard D33007 VG33
Here is the diagram for your connection. It may vary but most probably there are names are written on the mother board for the connections
Thanks.
Oct 22, 2010 | Gateway Computers & Internet
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
Apr 08, 2009 | Foxconn 661FX4MR-ES Motherboard
ATX-SW Motherboard?
The manufacturer website should have what you need.
You also might need to know what chipset is on the board as well.
If it is the AMD board, go to www.amd.com
I hope this helps.
Good Luck.
Feb 26, 2009 | Computers & Internet
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith. If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins. Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names. The power and reset switch will work no matter witch way around you put them. The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer. Regards mistyman
Sep 03, 2007 | FIC FR33E Motherboard
Gateway 3250X Media Center PC Desktop Logo
264 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
