Question about Sony PlayStation 2 Slimline Console
Ps2 slim scph-70012
Unit over heats. Is there a fan?
  • Anonymous Apr 12, 2008
    our ps2 blacks out how do i fix it?
    Problem Solver:
  • 5 Answers
Yes there is. its already built inside and blows to the rear right opening of the unit, you just wont feel it at first coz its too weak.
anyways, there's a 'usb fan' sold separately for the slimline and the fat one, but i'm not satisfied with its output either...so i just made my own cooling...
Posted on Apr 11, 2008
  • Anonymous Apr 22, 2008
    what do you mean by 'out'?
SOURCE:
I have a ps2 model # SCPH-70012. Its old n i got it from a pawn shop. So im guessig the warranty is up on it. It reads all audio and my claening disc... But no dvds or ps2 silver back games. Please help....
Maybe this will help. If u have no fear of opening ur ps2 (Google it), use a damp q-tip & gently clean the laser lens. If that dosen't work then the lens is about to go (it's to weak to read certain discs).
Jun 26, 2010 | Sony PlayStation 2 (PS2) Console
PS2 model # SCPH-70012 Disc will not spin and read the disc... How to fix it?
You need to replace the laser module. Get a replacement online or on ebay, swap it. that's it.
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
I have the PS2 model # SCPH-70012. I have taken
download? you mean play, sounds like your drive is dead
Jul 14, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 silm not working.
My PS2 slim wont spin a disc unless I put pressure on the top of it. As a temporary fix I place a 10 pound ******** on top of it while the PS2 is in the horizontal position.
Feb 02, 2009 | Sony PlayStation 2 (PS2) Console
How hdd connect with slim ps2
You cannot connect a usb hardrive or anything for that matter unless you "soft mod" the ps2 you need a pro action repaly and the usb stick that comes with it and you need to put certain installtion files on the stick with your computer.
Google: "Mod slim ps2 to play backups"
Feb 02, 2009 | Video Game Consoles & Games
We just purchased Guitar Hero and when we put it in our PS2 it dont spin the disk??
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc. If the fix doens't work then you need to send in your PS2 for service.
1) Start up the PS2 with no disc in it.
2) Highlight the 'Browser' menu and press the 'green triangle' button.
3) Highlight the 'Console' menu and press the 'green triangle' button.
4) Highlight the Diagnostics menu and press the 'blue X' button and select 'ON'.
5) Press the 'red O' button to back out of this menu.
6) Highlight the 'PlaystationDrive' menu and press the 'green triangle' button.
7) Highlight the 'Disc Speed' menu and press the 'blue X' button and select 'FAST'.
8) Press the 'red O' button to back out of this menu.
9) Turn off your PS2.
10) This step is optional.......I blew into the main unit to loosen any dust out of it and then carefully used my shirt to wipe across the lens at the back of the drive. I'm not sure if this mattered or not. Since I did this in conjuction with the above steps I can't say if this is needed.
11) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
12) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
I hope this works for you too!!
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
Which multitap do I buy?
There were two versions of the multi-tap made; one for the original fat PS2 and a smaller version made for the slim. The two versions are incompatible with the other PS2. If you have the original multi-tap connected to the slim, it should throw out the 'controller disconnected' message when you boot up. The slim version of the multi-tap should have a sticker on the bottom saying 'only works with models SCPH-70000, SCPH-75001, SCPH-75002'.
Other than the sports games, I don't recall any titles that allow more than two players anyway.
Nov 25, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
You have to have take your station apart and clean the eye... If u need to know how to do it without messing it up email me bak...
Mar 14, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
137 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
