Question about Dometic Rooftop RV Air Conditioner
Constant cycling My RV air conditioner cools then shuts off. In less than a minute it starts again, runs for a minute, shuts down and repeats this until it gets on your nerves. Doesn't seem normal. What's up?
  • 2 more comments
  • Chas T Apr 05, 2008
    Not using an inverter. Only circuit protection is a surge protector which is plugged in to the electric pedestal outside.
    Doesn't sound right. The unit will run continuously until it cools the room. Then it shuts down, is down for a very short time when it starts up again. It will run for a very short time with compressor and fan cooling the room. It runs for a very short time (one minute or less) when it shuts off again and the cycle continues in this fashion until I either push the thermostat down to keep it running or push it up to make it stop.
  • Chas T Apr 06, 2008
    "Enery Saver Mode"? This is a new one to me. What is this and how do I change or re-set it to the "working mode"? Thanks
  • Chas T Apr 07, 2008
    User manual does not have anything that refers to modes. The only setting that will shut off the unit after is cools is the "auto fan" setting. The fan can be set so that it shuts off after cooling or continues to run after reaching the set temperature. Having the unit set on auto fan is when the constant cycling problem occurs.
    Guru:
  • 1,894 Answers
Do you use a inverter.. or any protection circuit>
if so remove it and connect it directly
Posted on Apr 05, 2008
  • 2 more comments
  • dewan nafees ahmed Apr 05, 2008
    ok then problem is in your circuit board alone. all other components are very fine.
    it tries to start every time and then shuts off itself right?
    then wen it start s trying it shuts off due to some short in circuit.
    this can be looked manually or can be checked with a meter.
    this can be done manually by you if you are pretty handy in electronics.
    else best way is to call a tech to clear this problem.
  • dewan nafees ahmed Apr 06, 2008
    hey hello,
    yeah now the problem is explain in detailed.
    thanks for replying.
    your machine is working in "ENERGY SAVER MODE"
    this is the whole thing behind the problem.
    just change the working mode. keep it in cool always.
    that is the best.
  • dewan nafees ahmed Apr 07, 2008
    i think all the units like that will be having different modes of working.
    there wil be normally modes like warm, cool, enegry saver, and many other modes.
    in energy saver mode only unit will shut down itself once the room gets cooled.
    for the modes and how to change them you must refer to your user maual.
    then why not you remove it from auto fan mode?
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
My A C conpressor is cycleing realy fast, every few min. would it be the conpressor capacitor ?
No. It is "short cycling" probrably because it is low on refrigerant which means there is a leak somewhere. The refrigerant cools your compressor windings. If it is low it cannot cool the windings and it will stop the compressor due to a temp overload. As soon as the compressor cools back down it closes the bi-metal switch and allows the compressor to start again. The cycle will repeat itself until the compressor finally quits. Hope this helps.
Please rate my response on FixYa.com
Aug 03, 2011 | Dometic Rooftop RV Air Conditioner
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Aug 03, 2011 | Haier Heating & Cooling
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Cools nicely but then quits for a while but starts cooling again after 20 minutes or so. and keeps this cycle, not comfortablel at all.
Dirty coils/filter or low refrigerant will cause the unit to trip out on overload and shut down until the unit resets. Thats what causes the system to cycle in that manner.
The system needs to be cleaned and then the refrigerant charge can be checked properly. You may find it needs refrigerant as well.
Feb 02, 2010 | Dometic Rooftop RV Air Conditioner
Brisk air, dometic rv a/c unit
possible tired motor, or dying capasitor
Jun 24, 2008 | Dometic Rooftop RV Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
430 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
