Bosch front loading washer. rubber seal came lose and metal spring come off - what is the best way to put it back in place
  • wimbleton Apr 05, 2008
    I need to know (using a clock's face as reference) where the spring goes, i.e. at 6 o'clock. Also, when I try to put the metal band in place, it pulls the seal loose when I go to stretch the spring - is there a trick to putting it back?
    No, apparently clothing in the washer caught on the seal and pulled it loose and popped the metal ring off in the process. Clothing was tangled into a large knot. Seal is not damaged but I can't get the metal ring back into place.
    Guru:
  • 1,894 Answers
I think the rubber seal is getting heated..
check it out..
Posted on Apr 05, 2008
SOURCE:
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch Classixx - Rubber Door Seal - I heard the easiest way to get the inner ring back on is to remove the whole front panel - How do I do this?
Not recommended, tilt washer backwards, and work spring on with your fingers, slowly going round the inner lip of the seal, it helps if you can get someone to help by holding the spring in place as you work your round the seal.
Thanks.
Aug 27, 2009 | Bosch Classixx WFL 2066 Front Load Washer
FRONT DOOR OF WASHER LEAKING
Hello. W/D here.
It's actually pretty easy to get it back on when you know the trick.
Since it has leaked on you, you may want to remove the seal off of the rim closest to the door and clean the rim and the sealing surface. The seal has a molded lip that fits on to a raised formed rim, and it gets pressed on snugly before the ring and spring are added. You can seat the seal by pressing on it all the way around with the palms of your hands.
To install the ring:
Start the ring 180 degrees from the spring, placing it in the groove behind the seal face. (You want to make sure that the seal is pressed back into place first). Work the ring on around the seal, until you get to mostly just the spring remaining. Now lever the spring over the lip and into the groove, using a small screwdriver, being careful not to damage the seal with the screwdriver.
Best regards, --W/D--
Aug 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch wfm3200 rubber gasket
You need to turn the seal back in on iteself at the front, then starting at the 12-o clock position, start feeding the spring round into the recess you will feel at the rear edge of the seal, it is a goove and that is where the spring fits.
As you progrees round with the spring you will find it harder and harder to get it to stay in the groove, this where you could do with some assistance.
You need to have some one hold the spring in place as you progreeively fit the spring.
You may find you will have to have more than attempt.
As a last resort, you can stretch the spring, which will make it easyier to fit., but do not stretch it too much, or it will not stay on.
Plz leave feed back for this solution.
Dec 11, 2008 | Bosch WFMC 3200 Front Load Washer
Door seal fitting
Bosch Classixx WFC 2465 Front Load Washer Door
seal fitting.
This video will show you how to change a door seal on this Bosch front loader washing machine and how to get the spring
fixing ring back on.
we have all
Aug 12, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Rubber sean and wire spring came off
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Apr 05, 2008 | Bosch WFR 145 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
