Question about LG 42PX5D 42 in. Plasma HDTV
Lg plasma tv 42pc3dv
Tv audio ok, no picture only vertical and horizantal lines on about 90% of the screen the other section looks ok but it flickers and after 1 minute only the power button works
    Problem Solver:
  • 7 Answers
You will have to have a tech come check that one out, your gonna need your y-sustain, z-sustain and both y-drive boards replaced.. its a common issue try to get your warranty extended if its out.
Posted on Jun 02, 2008
SOURCE:
LG 50" Plasma / Flickers with vertical lines also
There are so many reasons for this fault. If you wish to get more details, check this link. It has screen-shots illustrations to faulty screens to plasma displays. You can see and compare it to your TVs' and can make sure about the faulty section circuit inside it. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | LG 50PC3D 50 in. Plasma Television
LG Plasma screen just went nuts
It could be any of 4 boards, either take it in for service or get a new set.
Nov 16, 2017 | LG 42PC3D 42 in. Plasma Television
Vertical black lines. But they are not solid. lg plasma 42pc3dv
This could be a poor connection with the LVDS cable which runs from the main video processing board to the screen, or a fault within the video processor on the main board. Worst case scenario is it could be a fault with the screen itself.
Jan 08, 2010 | LG 42PC3DV 42 in. Plasma EDTV
Backlight video ? lg plasma 42pc3d
It is only LCD's that use backlights, Plasma TV's use a different concept to produce the picture. I assume you have no picture, this does not mean the screen is faulty. It could be either a sustain board or control board fault.
Nov 27, 2009 | LG 42PC3DV 42 in. Plasma EDTV
42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Mar 07, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
No picture
hello,
this problem accure due to vertical o/p ic is failiur so plz checked it from any hardware engineer or if you changed it. you are welcome. i't mostly 9 pin ic on heat sink. it's mostly located at the horizantal _ vertical coil's wire( 4 wire attached with pcb) are placed.
ok
bye
Aug 30, 2007 | Samsung 21" FLAT CRT COLOR MONITOR
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
LG 42PX5D 42 in. Plasma HDTV Logo
124 people viewed this question
Ekse
