Question about HP Color LaserJet 2600n Printer
Installation I can't unlock the paper tray. Where is the paper tray lock and how do you release it?
  • 236 Answers
There should be no "lock" on the tray.. I would assume you mean the second tray, you should be able to just pull it out...
Do you have the instructions??? they can be found here if you dont'. Check page 41 for loading trays...
Posted on Apr 05, 2008
  • Dave MacPhee
    Dave MacPhee Apr 06, 2008
    Did the paper tray slide out?
  • Dave MacPhee
    If you are talking about the actual lock, once the tray is slid out, it is an orange plastic thing..
    Slide the orange paper tray lock towards the rear of the paper tray.
    Remove the orange paper tray lock
How to Unlocked Disk Tray when i press eject button it show locked
Generally all,have a hole, to which a paper clip will fit to release tray lock.
Feb 13, 2015 | Televison & Video
Paper tray problem - full of paper but can't pull up paper and display says tray empty also loud clicking noise coming from paper tray
hopefully we can stop problem before it gets worse, take paper tray all the way out of machine, look at back of tray where paper stop is, move to LTR make sure arrow is pointing directly to it, not before od after, then lock it in, the pictograhm has a pad lock symbol to show locked and unlocked. if the blue tape is still in paper tray, remove it. hopefully no damage done to pick up assembly, or gears on paper tray
Sep 25, 2010 | Brother MFC-8460N All-In-One Printer
Paper to narrow?
To print into a paper that seemed narrow compared to the printer's tray size, just move the lock located at the paper tray. Press the "locks" and slide it to "enclose" the width of your paper. When you release it, it is locked in place so your paper will print just fine.
Feb 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Eject lock
Get a paper clip and unbend it so you have a straight wire. Then look closely at the dvd tray and next to the eject button you will see a tiny hole. Push the paperclip wire into the hole and manually release the dvd tray.
Feb 09, 2009 | LG LFD790 System
The other lock
If the key is removed, the lock is gone from it.  It's just a clear piece of plastic in there.  What could be causing the L1 to happen is the ribbon cable underneath the scanner glass is out of place causing the scanner to stall.  This is a common problem with the AL copier line.  You can take the scanner glass off and check the cable for any binding going on with it.
Sep 07, 2008 | Sharp AL 1215 Black and White Copier
Paper Tray will not open
Maybe a broken or losen paperguide under the paper pick-up ***'y is your problem or the mechanisme that unlocks the paper lift plate in the tray is not functional, try to unlock this plate from the back of the printer by pushing it while pulling the paper tray out, good luck
May 04, 2008 | HP Color LaserJet 2600n Printer
Disc tray locked on JVC XV-N322
there is a small hole in the front of the tray that will accept a straightened paper-clip. gently insert the clip and the tray should release. if the cd/dvd disc is dislodged from being flat in the tray, it may not come out. you might need to open the cover and manipulate the disc to get it back flat in the tray. a good first test is to see if the disc plays. if it does, it is in the tray correctly and should be easily released with the paper clip. the try might work after you release it.
another possible first try would be to gently push inward on the tray after telling it to release. if there is extra tension on the tray it could cause the mechanism to not release. freeing the tension on the tray could be all that you need to get the 'unlock' to release. (kinda like trying to open a door when someone is pushing it very hard against the lock mechanism. it wont be able to move).
good luck
mark
Jan 03, 2008 | Televison & Video
Loud clicking noise
This is one of the known issues with the HL-5240. This will require a replacement paper tray. Definately the problem if it is more of a clack than a click.
Sep 18, 2007 | Brother HL-5240 Laser Printer
HP Color LaserJet 2600n Printer Logo
74 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
