The on and off button does not work all the time, sometimes it takes 5 to 10 min to get to work, can you please advise me on what to do?..thanks
Jodete maldito tu boton esta loco y aqien le importa muerete
Posted on Apr 14, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Probably a mechanical problem. I have a Gateway in which the button actually fell out--then I could reliably turn it on with a Phillips head screwdriver. Take your case apart and see whas happnin with your button.
Posted on Apr 05, 2008
Honda hrb 216 shuts off after bout 15 min after sitting for a while....then shuts off every couple min....something is effecting gas flow it appears.....anybody had this issue plls advise...thx
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 01, 2010 | Honda Garden
Blue screen
Please press f1 ,it will take u to bios ,reset that with f5.......
and also after that remove each and evry cable and then press power button for 1 min and then replug the cable
May 01, 2010 | Microsoft Windows XP Professional SP2
Is it normal to be waiting for 5 min to download a film clip of 1 min. from YouTube? What it depends on? The wideband connection, the Processor ? Or somthing else. Thanks for your answering.
Thanks for writing to Fixya.
No it does not take 5 mins to download a film clip of 1 min. Does this happen with all clips. If yes then its a wideband connection problem. Sometimes you would see certain clips downloading fast and some taking some time. In such cases its a server problem specially where the clip resides.
Hope I could explain. If yes please accept.
Thanks
Apr 22, 2010 | YouTube Videos
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Lifefitness 9100hr treadmill cut out
iv had similar problems, only happened once tho - i switched it on after a few mins it would go off.
iv read to dismantle the stop switch, clean and replace the microswitch. where can the microswitch be found from?
also, is the red stop switch that needs looking at? how can i remove it?
i was wondering on how i can service/maintain this properly, can anyone advise my on how to give this a service.
Jul 14, 2009 | Life Fitness 9100 Next Generation...
Boost Mobile Motorola i730 PTT (Chirp/Two Way Button Not Working)
you should be able to get a used one cheap, if you want to keep that one. use a T8 screw driver to open it, if the little button inside has broken free from the solder, i would advise a new phone, or send it in here to replace the board, it should not cost more then 20.00 us
http://multiplexelectronics.home.att.net/phonerepairs.html
Jun 12, 2009 | Motorola Mobility i730 Cellular Phone
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
Device is inoperable
I've had the same problem since the first time I tried to turn it on. I have to press the on button 20-25 times over a period of 5 min. to get it to work.
Feb 01, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Maytag Nuptune Washer
These units seem to all use the same control board and have the same issues. the intermittent and door lock issues are random and frustrating. it will take a person that wants to fix it. see this link for what to do. I have other links that explain the same.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Oct 03, 2007 | Maytag MAH8700A Front Load Washer
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
