Question about Proscan PS27115 27" TV
DVD input failure
DVD player works find when audio and video jacks are connected to another television, but fails with my Proscan PS27115. Cable inputs from VCR player and cable provider work fine. Picture is fine.
The DVD player did work with this TV a few months ago.
Suggestions please---
Many thanks, Gary
  • 2 more comments
  • Gary Silberstein Apr 05, 2008
    sweet_rascal suggested trying an hdmi input. This tv is ten years old and doesn't have an hdmi plug-in. There are three input jack plug-ins: yellow=video, red/white = lft/rt audio. Signal from the KLH DVD player is not getting through to the televison.
    "can u plug ur cable correctly in bhind or in front of your tv?" cable is connected ok. " thats socats come so plug ur socact bhind the tv try to on ur dvd player" I can't make out the abbreviation 'socat', so I can't understand the advice.
    Fact is there are only three jack inputs. Not much room to experiment! What about some failure in the TV circuitry?
    Your advice is consistent with where the failure seems to be. I'll try what you suggest tomorrow am and let you know what I find. Thank you.
  • Gary Silberstein Apr 06, 2008
    I removed the back and checked for loose connections, etc. Pretty dense back there so couldn't tell if a board was damaged, etc.
    The gentle wack had no effect.
    Decided this ten-year old TV was due for replacement.
    thanks for your help,
    g
  • 3,037 Answers
It probably is some failure in the circuitry between the input and the board or even on the board, try giving the tv a couple of gentle wacks to see if that helps anything. You may have a loose connection in the tv. If you know how to and can safely perform the following, then do so.
1. take off the back panel of the tv.
2. Look for loose wires, move the wires that go from the input to the board and see if anything happens
3. Look for metal pieces that are lose on the board or between the connections, look at points that are soldered that may have broken.
Please let me know what you find and give me an update, thank you
Posted on Apr 05, 2008
  • Benjamin Patri
    Benjamin Patri Apr 05, 2008
    ok, sounds good
  • Benjamin Patri
    Benjamin Patri Apr 07, 2008
    please don't forget to rate this solution and good luck on picking out a new tv. My advice is to read reviews before buying one
    Have a good day
  • 813 Answers
Hi friend
in bhind or in front of your tv thats socats come so plug ur socact bhind the tv try to on ur dvd player
  • sandip panchal
    sandip panchal Apr 05, 2008
    i think ur cable is bed so change the cable & try to on it
    Guru:
  • 1,894 Answers
Use a hdmi input and try the same
How do I connect the wireing
The VCR portion is connected to yhe TV via yellow-end cable(video) from "video out" to TVs "video in" and red and white-end cables(audio) from "audio out" to TVs "audio in". The DVD plays via HDMI cable from "HDMI out" to TVs HDMI in. S-video cable can be used if no HDMI terminal is available on TV. External tuner in (cable TV, Satellite) is connected to the video and audio in terminals or better yet if S-video out is available on the tuner box.
Aug 24, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
Connect DVD player to TV red white and yellow wires
1. Connect the audio cables to the AUDIO OUT L (left - white) and R (right - red) jacks on the back of
your DVD Player, and to the corresponding Audio Input jacks on your TV.
2. Connect the video cable.
• Basic video connection
- Connect the video cable (yellow) to the VIDEO OUT jack on the back of
your DVD Player, and to the Video Input jack on your TV.
OR
S-Video
(optional) - If your TV has an S-Video Input jack, connect the S-Video cable to the
S-VIDEO OUT jack on the back of your DVD Player and to the S-Video jack on your TV. If your
TV doesn't have S-Video, use the basic video connection listed above.
Mar 18, 2014 | RCA RC5240P DVD Player
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I have a proscan tv model #PS27108, I do not know how to hook up the dvd player in regards to the cords and what channel to put it on? I would appreciate any help with this! Thanks in advance?
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in.
90 selects S-video and audio 1 in
91 selects composite and audio 1 in
92 selects composite in 2 and audio 2 in
Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD.
If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4.
tom
Oct 22, 2009 | Proscan PS27108 TV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Tv magnovox tv
firstly try that tv to a different tv
if this works
then check your tv av connections in side tv
also check cables continuity
if this fails buy a AV/ RF converter, have your AV be connected to a converter, and let your output be RF feed to a tv, RF input, so instead of using AV on your tv you will be using RFchannel mode
Mar 16, 2009 | Philips Magnavox 27MS343S 27" TV
Proscan Svideo Input
Try Googling (proscan)(PS27115)(manual) without parens.
Jul 15, 2017 | Proscan PS27115 27" TV
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
