Question about Motorola Mobility RAZR V3
I tryed to switch service to this phone and it wont let me program it.....
I tryed to hook up service to this phone and when we program it it wont take the programming so what do i do to fix this...........
    Problem Solver:
  • 21 Answers
You may have to unlock the phone with a subsidy code first of all. YOu may also try resetting it.
Posted on Apr 05, 2008
SOURCE:
Straighttalk phone troubleshooting
Try doing a soft reset by holding power button and home button at the same time until you see the apple logo than let go and let it reboot or try hooking it up to Itunes both of these have worked for me in the past good luck hope this helps you
Dec 28, 2013 | AT&T Cell Phones
Norstar phone is automatically sending hook flash (or conference transfer) signal through active calls. Places outside caller on hold and can only reconnect by using feature 71. How can I avoid this?
Could be a sticky button that is programmed for F71
Do F*0 then press all buttons and look at display until you see Link or F71 on the display. Try to un stick that button or erase it via F*1, press that key and press OK instead of entering digits.
or the spring on the grey hook switch is sensitive, this where you hangup the phone. To do a hook flash when no flash/link key you would tap the hook switch very quick to do a hook flash (link).
Send set in for repair in this case.
Oct 23, 2012 | NorStar Meridian M2250 Console Phone
I have an NEC Dterm Series i, It is (Night Switched ) How do i turn this off ?
Assuming that the station 100 is asigned to ports 1 or 2 and that they are in Att class 0. Nite switch can be tested manually by pressing the following with the fone on hook..
Press Feature + 80 + Feature. If this does not work and the above criteria have been met you may have to get a service tech to enable manual nite servive in the operator CLS.. If this works you can program from that fone a manual nite button buy doing .
Fone on hook. Feature + redial + press button to program + #80 + ANS + Feature + Feature. This will give you a nite toggle button.
Oct 28, 2010 | Cell Phones
Nokia 6234 headset symbol wont switch off - have tried switching phone off and removing battery; tried cleaning connection plug but still wont switch off - having to use loudspeaker to use phone... please...
Do a master reset from settings where the factory code is 12345. If this ain the problem take it to a service and they will do that for free because this is a common 6234 problem and one of the many problems that determinated the Nokia company to stop producing this type of phone!
Oct 22, 2009 | Nokia 6234 Cellular Phone
No Light to show off hook
Start by going to the phones that need to have the button fixed.
Press:
[Program], [9][9], [Button] (you should see an incorrect ext number), [2], [Correct ext number] and [Store]
You may need to repeat this at all phones that need the corrected light.
Jan 17, 2008 | Panasonic KX-T7453 Corded Phone
Wont Turn on
while charging your phone try to switch on your phone .or just try to switch on and switch off your phone 3-4 times continiously even if dosent work take it to the authorised service center
Dec 26, 2007 | Motorola Mobility V365 Cellular Phone
Toshiba dkt 2020
These phones do not store information of any kind. All the programming and memory is in the phone system itself.
The phone only works in speakerphone mode because the hook switch is broken. It is a VERY common problem that will happen to all of these Toshiba DKT2000 series phones at some point. The hook switch starts out just disconnecting calls and eventually will not let you use the handset at all. Unfortunately the problem can actually get worse even when the phone is not in use. That is why buying this series used is dangerous. Make sure the seller has replaced the hook switch and try to get a warranty.
Oct 19, 2007 | Toshiba DKT-2020 Corded Phone
Motorola Mobility RAZR V3 Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
