Question about Lanzar VIBE266 Car Audio Amplifier
Annoying thump from two 15" kicker comps powered by a lanzar vibe 266 amp
My amp has a constant but load thump that makes all my lights dim even if i turn the subs off with my headunit and i dont know how to fix it.
  • 631 Answers
It sounds like it may be oscillating. This can be caused by a broken ground in the signal line. You need to check the RCA shield on the head unit.You'll need an ohm meter. The following page has more details. If the head unit isn't damaged, the shield ground could be open in the amplifier.
Temporary Shield Repair
Posted on Apr 05, 2008
SOURCE:
I have a lanzar vibe pro VBP251 2200 watts and two 12" kicker comp subs. What do I set the amp on
You need to figure out what ohm capacity is of the amp and the speakers. It then comes down to wiring.
Mar 02, 2015 | Kicker Car Audio & Video
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
Can I hook up 2 lanzar opti1532 subs 2 a kicker kx 1200.1 or do I need a bigger amp, its a 1ohm stable amp an birth sheet says 1390watts but they told me at 14+ volts it will do 1400rms
Based solely on spec sheet information the Lanzars can handle 1300 watts RMS and the KX1200 is rated at 300x1 @ 4 ohms, 600x1 @ 2 ohms, & 1200x1 @ 1 ohm. Even with a 1 ohm load you will still only be providing 600 watts to each sub. While the kicker will provide more power at 14+ volts, no car creates more than 12-13 volts via its alternator. A car battery only provides 12.6 volts. So you will be loking at 1200 watts from 1 channel as a best case scenario.
Additionally, with your 2 subs, they will need to both be Dual 4 ohm voice coils in order to net a 1 ohm final load. Each voice coil will need to be wired in parallel and then each speaker needs to be wired in parallel.
Dec 23, 2010 | Lanzar OPTI1532D Car Subwoofer
I have a Lanzar Vibe 235 amp. the green power light is not coming on, but the red "protect" light is. how do i solve this problem??
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to purchase an old school Lanzar Opti Drive. Any of them. The 50 will kill some 12" subs .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe-235-amp-green-power-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Mar 11, 2010 | Lanzar Vibe 235 Car Audio Amplifier
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
I have a 600watt vibe amp all wires are connected correctly but power light comes on and then goes straight off and repeats this constantly whats wrong??
most amp have a protection feature sounds like somthing is hooked up wrong or u have a short to ground id recheck using a multi meter if all test r good then ur amp needs to be serviced.
Sep 17, 2009 | Lanzar - Vibe: 2 Channel 600W Vibe Series...
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
I need repair help. no schematics
Blown Mosfets
A thumbs up would be greatly appreciated if this answer is helpful to you. need-repair-help-no-schematics-zb4bomd1rt4qms0dqd12kkt2-5-0.jpg
Nov 08, 2008 | Lanzar VIBE266 Car Audio Amplifier
Lanzar VIBE266 Car Audio Amplifier Logo
112 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
