Question about Lexmark X3550 All-In-One Printer
Printer doesn't print
Once i send the documents to the printer, it won't print
  • Anonymous Oct 21, 2008
    Paper feeds through but does not print
  • 57 Answers
Try to check your setting of the cabl4e if you using USB select USB if serial set it to serial cable then go to the control panel double click printer and faxes set your printer as a default then try to print again
Posted on Apr 05, 2008
SOURCE:
Dell printer will not complete task. If printer is uninstalled then reinstalled it will print one time but doesn't complete the task on the "printing screen". I go to the printer window...
Hi Bill,
Have you tried the printers on another PC?Please do.
  • Whats the Operating System on your PC?Do the printer drivers correspond with that Operating System?If not,download the corresponding drivers from this dell support site. This you select under compatibility.
  • After uninstalling the printer,disconnect fully and unplug from power.Reboot your PC before installing the printer again.
Hope this helps.Thanks!
Nov 01, 2011 | Dell V305w All-In-One R840635AU InkJet...
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
The file currently in the print cue won't print. I tried to cancel the print but it won't delete. I uplugged the printer, did a restart, same problem. I tried to uninstall the driver, no luck as...
Try looking on the bottom right side of your pc, near the clock to find the picture of the printer or Icon for the print Que. Sometimes you have to click on a little arrow in this area to open it up and view all available. Find the picture of the printer and right click with your mouse on top of it. choose all printers and this should bring up a list of documents which have failed to print. Find the document and click on it then choose "delete" until there are none left on the list. make sure you use the "all printers" choice and not just the one listed in the name of your printer to clear this que. if this does not work, let me know by using the comment or reply links next to your question on Fixya and I will send more troubleshooting instructions.
Sep 12, 2011 | Dell 942 All-In-One InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Printer will not print e-mails
Once you give print command of an email, your email program should ask you to select printer.
If you are using MS Office, by default One Note printer might be selected.
Please check which printer is assigned when you click print.
I hope this information helps.
May 11, 2011 | HP LaserJet 1020 Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
HP Photosmart 3210
Try reinstalling your display drivers. you'll be surprised how dependent printers are on display drivers. Try changing the font as well.
Do you get any error messages once you click the print button? is it sending to the correct printer?
Jun 15, 2008 | HP Photosmart 3210 Printer
Printing problem
This error message indicates that the printer memory is full. You might be sending too many documents to print at the same time. I would suggest dividing the number of documents/pages into smaller groups so the printer can take the load. Hope this helps!
Feb 22, 2006 | Xerox 6100/DN Laser Printer
Lexmark X3550 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
