Question about Zanussi F1045W Front Load Washer
Door wont open, stopped spinning - Zanussi F1045W Front Load Washer
  • 1 more comment
  • Anonymous Jun 17, 2008
    my top loading washer door wont open. need it baddddddddddddd. tried prying with knife, put it through rinse cycle again. no go
  • Anonymous Nov 04, 2008
    1. door not opening after wash
  • jamcpherson Dec 01, 2008
    I cleaned the interior of the washer per the directions of the manual and now the door won't open. I tried doing a rinse and a spin - door still wouldn't open, so then I did a wash - door still not opening???
    Genius:
  • 1,665 Answers
HOW fix myadmiral washer model AED4475tq0
check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
Jan 14, 2015 | Admiral Washing Machines
Open the door on dryer the drum still spinning and wont stop
Hi, You need a new door (switch) that turns the dryer off when you open the door. Replace it.
Jul 21, 2011 | Dryers
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Washer wont spin
WASHER DON'T SPIN
normally if is filled with water an does not spin, check ur door switch may be bad or broken also check the lid make sure the smaill white tab is there too, the switch normally break when someone stands or slamms the lid hard or puts heavy baskets over the lid ,the switch mounting screws base is made out of plastic so is easy for it to split
the lid switch is a safety device that stops the machine while on spin cycle, in case you forgot your wallet u go back to get it stick ur hand in it, and is on spin cycle, as soon as u open the door, the door will deactivate the power tho the washer, and the basket will stop, when not going into spin mode is one of the main reasons
good luck leave some feedback!
Feb 01, 2010 | Washing Machines
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Zanussi F1045W Front Load Washer Logo
132 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
