Question about Intel Motherboard
DDR SLOTS INSTEAD OF SDRAM
I bought more ram for my fairly old pc, I had two sticks of 256 sdram, and ran a compatibility check on new ram from 4allmemory.com and I went with one of the recommended selections of two: 512mb ddr-266 (pc2100).
I assume my memory sockets 1 and 2 are for PC133 sdram DIMMS and memory sockets 3 and 4 are for the ddr 200/266 sdram dimms and can't be used together per a system scan by the website.
When I went to put the new ddr in I took out the two 256 sdram and saw that the new ddr wouldn't fit in slots 1 and 2 anyway so I assumed 3 and 4 were for the ddr. When I put them in I noticed they had to face the opposite way that slots 1 and 2 were but they fit. My pc didn't accept it because it was a slow beeping sound. I'm thinking I may have to configure a bios setting perhaps to allow it to recognize the ddr instead of the originals in slots 1 and 2. I dont have a manual for the motehrboard, but it looks like motherboard is : ITE, IT8705F, 0239-FXS, MFL6W0. I haven't contacted 4allmemory.com yet but says its guaranteed to work.??? Help Please
  • 1 more comment
  • Seeker1969 Apr 05, 2008
    BJ,
    I've gathered quite a bit of info that I'll include below:
    This is a desktop pc. I have gathered bios data by pauing the screen upon startup and wrote down:(c)American Megatrends,release 09/05/2002,amibios (c)2001 Amercian Megatrends, bios number is: 62-0905-001131-00101111-040201-VIA_P6-M925
    I've also did your suggestion to run Belarc Advisor (awesome info) and I think what I needed from that report is the "Main Circuit Board" info, right? Board is ECS M925 1.0,bus clock at 100 megahertz,bios is American Megatrends Inc. 07.00T 04/02/01
    "System Model" desktop enclosure and shows: =ECS=M925=1.0
    Slots 0, 1, 2, 3 with my 256 MB in slots 0 and 1. MY NEW DDR sticks need to go in slots 2 and 3, and it won't work with what I have in 0 and 1 from what I'm gathering.
    Another link you sent me, then by typing in bios code,shows that I think my chipset might be Hsin Tech, does that mean I need to pursue seeking an instruction manual from them to see how I proceed. Will I need a bios update, just a bios setting adjusted, a dipswitch moved, or will the DDr not work at all eventhough it was guaranteed to be compatible???? Those are my questions, am I getting closer to a solution?
    Thanks to everyone who have contributed with assistance and all of the helpful links and especially my motherboard manual from Pterocarpous. As it turns out all I needed to do was pull out or open the connector between the 4 slots and now my 2 new sticks of DIMM are recognized. I knew it wouldn't work, but just for kicks I tried the 2 sticks of Dimm ALONG with the original 2 sticks of 256 Sdram I had in the first 2 slots, and I didn't get the beeping sound however the monitor displayed out of range, so I shut it back down took out the Sdram and left in the two 512 sticks of Dimm, so I now have about a gig to use. Thanks again everyone!!!!
  • Anonymous May 11, 2010
    Hello Seeker1969
    The best I could tell in my research, ITE manufacturers components on the board but it is not the motherboard manufacturer.
    Where is this motherboard located?
    (01) Is it in a desktop PC?
    (02) Is it in a laptop PC?
    (03) If it's in a desktop PC, is this a manufactured PC (Gateway, Dell, etc.)? If so, what is the make and model of the PC?
    (04) If it's in a laptop PC, what is the make and model of the laptop?
    (05) Have you been able to get into the BIOS?
    If you haven't been able to yet, HERE is a reference for entering various manufactures' BIOS' that might be helpful.
    If you could, please, get the system back up and running (w/ the original RAM).
    Then download and install Belarc Advisor (a free PC audit utility). You can find it HERE on Belarc's web site.
    Belarc Advisor will perform an audit of your system hardware (and software). Hopefully, it will be able to identify your motherboard.
    W/ that info., we may get lucky and be able to find documentation on your motherboard. I will warn you that if the motherboard was manufactured by an obscure "off shore" company, we'll be hard-pressed to find documentation for it.
    I've used a company called MemoryX for hard-to-find memory and have been happy w/ their service. If you decide you're not satisfied w/ 4allmemory, you might like to give them a try.
    Please, post back w/ your answers and any other info. you can provide (the more details you can provide the better) and we'll see if we can get this sorted out for you.
    Thank you
    BJ
    Sergeant:
  • 202 Answers
Good work seeker 1969! Guess what I found???
It took a lot of sleuth work but....
Go HERE for your motherboard manual. :)
It's a zipped Microsoft Word document file. I've scanned it. It's virus-free. All the information that you need is there. Go to page 11 for instructions (including illustrations) for installing SDRAM and DDR RAM.
Please, let me know if this response was "Helpful" or a "FixYa" for you or, of course, if you have more questions, etc on this topic.
If I did not answer your question satisfactorially, please, b4 assigning a "Thanks for Trying" or lower rating to my "Solution", let me know. I may have misunderstood you or the problem you are experiencing. I will work w/ you until your problem is resolved or diagnosed. I promise! :)
Thank you
BJ
Posted on Apr 05, 2008
  • 2 more comments
  • Anonymous Apr 05, 2008
    As is usually the case, you cannot use SDRAM and DDR SDRAM simultaneously on this board.
    The slots closest to the CPU are the DDR slots.
    The other two are SDRAM slots.
    The jumper settings for this board are outlined on page 13.
    Go to page 14 for your memory voltage jumpering instructions. This is very important as the SDRAM and DDR SDRAM have different voltage requirements.
    (unbuffered) SDRAM: 168-pin 3.3v
    (unbuffered) DDR SDRAM: 184-pin 2.5v
    SOME MORE LINKS THAT YOU MIGHT FIND HELPFUL:
    Another handy hardware audit utility is CPU-Z
    You can find it HERE.
    ECS (Elite Group) Home page: HERE
    ECS Motherboard Archives (your board isn't listed there, however): HERE
    You can submit a support ticket HERE on ECS' site.
    Congratulations! I'm glad you're cookin' now.
    Enjoy!
  • Anonymous Apr 11, 2008
    I neglected to thank you for the "FixYa" rating. So, "Thank You!", Seeker1969. :)
    Please, don't hesitate to come back anytime w/ your questions or problems. We're here to help.
    BJ @:)
    Problem Solver:
  • 16 Answers
Hello
Betwin the two couples of memory soket it must be ajumper that guives you the abilitie to change over the frequency rate when you change your memory model .
If there is no jumper try to check if they are not using a strap soldered in the mother board then you will need some electronic skills to change over your frequency
SOURCE:
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
I want to add memory to my computer but do not know what brand or type to get. I have an Emachines desktop PC with the current memory of 256 mb (DDR SDRAM). I play graphic games alot.
Hello
The best way for you to upgrade your ram DDR SDRAM, is to take your current chip to your nearest dealer and they will tell you exactly what the price and brand will be. You can even try to bargain so that you do a trade in with your current chip. Really hope this can help you.
Best regards
Sep 28, 2009 | E-Machines T3504 PC Desktop
New ram cards to upgrade, now won't run windows
make sure both cards ole & nu....are the same (256mb...sdram...133speed)....and unplugged pc when replaceing battery/memory...have fun playing games
Jul 14, 2009 | Computers & Internet
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Toshiba Satellite A215-S7407 ram upgrade
Try to disconnect the new ram you just bought one at the time to see which one is defective. Also, 32 bit operating systems won't detect 4 Gb or ram, but they will show 3 Gb (even though they will use all 4 Gb). To resolve this issue, make sure that if you are using windows Vista to download the latest service pack 1.
Apr 03, 2009 | Toshiba Satellite A215-S7407 Notebook
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Intel Motherboard Logo
217 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
