Question about Dryers
Trying to open unit to change thermal fuse
Trying to change thermal fuse, how to get at it?
  • 725 Answers
Need model number and I can help krazytech
Posted on Apr 05, 2008
I changed my thermal fuse on my Bunn grx-b because it was not heating the water. Now it's like it is overheating. What could it be
hope this is of some help
the thermal fuse is blowing because the unit is getting to hot you replacing the thermal fuse has not cured the problem, and it will blow again , the problem is the thermostat is set to high or is faulty / allowing the unit to go over temperature hence the thermal fuse blowing
its the control stat that you should be looking at. good luck
Nov 19, 2016 | Bunn Coffee Makers & Espresso Machines
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
Short Circuit in changing light bulb in KHMS147SS has caused the unit to power completely down. Is there a fuse?
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 23, 2012 | Microwave Ovens
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
My Starbucks Sirena Espresso Machine wont turn on. nothing happens. nada zip. I suspect its the power button itself. Do these things have fuses?
The thermal fuse in my Starbucks Sirena Expresso Machine failed. You will know if it has failed if you unit doesn't turn on and/or your unit doesn't produce steam. This expresso machine is a double boiler unit and the thermal fuse is located in the steamer boiler (boiler closest to the top of the unit). The fuse is actually wedged into the steam boiler. Make sure the unit is unplugged. Remove the water reservoir then remove the 4 screws that hold the reservoir housing in place (you will need a torx wrench for 2 of the screws). Next remove the warming lid on the top of the unit by lifting it from the back. Remove the 4 screws that hold the metal upper cover in place. You may need to remove the 2 screws that hold the front panel in place to have enough room to loosen the thermal fuse fixing plate. Unplug the wires that plug into steamer knob control unit. Remove the protective cover to the steam boiler. Loosen the screw to the thermal fuse fixing plate. Remove the thermal fuse and replace with new fuse. Do not solder in the new fuse otherwise you may cause the fuse to fail due to the heat of soldering. The original fuse is a 233 Celcius and 15A. I purchased a thermal fuse from radio shack that is rated at 228 Celcius and 10A (http://www.radioshack.com/product/index.jsp?productId=2102788). So far it works fine. You can also purchase thermal fuses from http://www.goodmans.net/get_list_632_2.htm. For a schematic go to http://www.saecoparts.com/user/Sirena SIN 025RX explodeddiagram.pdf.
Apr 20, 2010 | Saeco Starbucks Sirena Espresso Machine
SHARP AR-160 IS BLINKING H 2 WHAT IS THIS
Hi
Thanks for using FixYa. Error H2-0 means Fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor please change the thermistor of heater unit, and also check the thermal fuse. This error also occurs when the upper heater thermistor is open or the fusing unit is not installed when the door is closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | Sharp AR-160 Copier
Drum doesn't turn, but the light is still turns on. No noise indicating the electric motor is trying to turn the drum. I opened the top and verified the drive belt is intact and taut.
First, please keep in mind that i am attempting to diagnose your unit with out being there and with limited information.
If I were called out to your home to repair this problem, I would first check your breaker. I would flip it off and then back on. If this didn't fix the problem. I would then check the door switch. If it's good, I would then open the back and check the thermal fuse and then the Thermal cut off. If either were bad I would change it. If it were the thermal cutoff. I would also change you high limit because when the thermal cutoff is bad, it is due to the high limit thermostat going bad, then the dryer cycling on the thermal cut off until it goes bad causing a problem like what you have.
Please rate solution
Sep 08, 2009 | Whirlpool Dryers
Black & Decker BDCH200C Ceramic Heater
There is a thermal fuse in this heater. A 133 deg. C fuse along with a bimetalic thermal cutout is attached to the top of the ceramic heater housing. This fuse is probably open, and is the most likely cause of your problem. This fuse is riveted in place, and is not easy to change.
Opening the heater case requires a special anti-tamper screwdriver. B&D don't want you inside this unit.
Apr 23, 2008 | Black & Decker BDCH200 Ceramic Compact...
Respond doc
Vulb,
Having had to change the lamp I would suspect the lamp thermal fuse is open... It's located over the duct for the fan housing and solders into the ballast board.. Check it for continuity and if open replace it..
There are several thermal fuses in that unit and not all of them as easy to access as the lamp one.
Good Luck
Bill
Nov 17, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Dryers Logo
85 people viewed this question
Top Dryers Experts
