Question about Intel Motherboard
Evertime i load windows 98
I load windows 98 on the hard drive it drops out my cd rom my board is 945ct-m i have xp to put on it but it drops out the cdrom
  • coorsman2677 Apr 05, 2008
    tried that to but all i have is the upgrade windows xp
    Problem Solver:
  • 6 Answers
Just boot in dos mode ok then install windows xp
Posted on Apr 05, 2008
SOURCE:
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
Can not install windows xp in my system send error code 7
try this one:
To resolve this issue:
  1. If you are upgrading Windows 98 or Windows Millennium Edition, follow the troubleshooting steps that are described in the following Microsoft Knowledge Base article: 310064 (http://support.microsoft.com/kb/310064/ ) HOW TO: Troubleshoot Windows XP Problems During Installation When You Upgrade from Windows 98 or Windows Me Test to determine if the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to the next step.
  2. Perform a clean installation of Windows XP:
    1. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive.
    2. If Windows automatically detects the CD-ROM, click Install Windows to start the Windows XP Setup Wizard. If Windows does not automatically detect the CD-ROM, click Start, click Run, type CD-ROM drive letter:\setup.exe, and then click OK.
    3. Press ENTER.
    4. Click New Installation, and then click Next.
    5. Follow the instructions on your screen.
  3. When you receive the "Press F6 to load SCSI/Raid Drivers" prompt, press F7 to bypass Advanced Configuration and PowerInterface (ACPI) detection.
  4. Finish the installation of Windows XP.
Mar 13, 2010 | Computers & Internet
French Dictionary CD Rom dated 2000 for Windows 95-98.
Yes, you can. Copy the disc on the hard drive of your computer. Right click on the .exe file, go to compatibility tab, check for Windows 98, Ok. And after that run the install as normal
Feb 17, 2010 | Video Game Consoles & Games
Cd rom will not read. have just put windows 98 on instead of xp, hard disc was formated, have win 98 now, but cd wont work or if i plug in usb memory stick
With Windows 98 you MUST install a suitable driver in addition to Windows 98 to talk to CD Roms. I believe there is also a general service routine that must be loaded.
XP has all this functionality built in.
Try this site to solve your problem:
http://www.computerhope.com/download/hardware.htm
Nov 07, 2009 | Acer Aspire One PC Notebook
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
I have a 600E that had the hard drive reformatted. I don't have a boot disk for the system (only has CD drive) but it won't boot from that when I try to reinstall Win 98. Got any suggestions?
Your cpu is slower than I was thinking of. However you should be able to load XP. When you load XP remove all partitions and set it up on NTFS. Go for a full installation, load, anti virus and any utilities that you want. Get yourself an external hard drive and save all your folders to that after you have finished working on them. That way you will free up your cpu to manage. If you still want to load 98. Try going into the Bios and set the CD drive as your first boot option, with a bit of luck it may work. Once you have loaded your operating system be it 98 or XP, go back into the bios and re-set your boot preferences to HDD then CD Rom. Failing that I can not help you any futher. You may think of up grading to at least a P3 in the future. Another point. Borrow a copy of windows XP from a friend and install that, if it loads ok then you can obtain your own copy if you want to.
Dec 07, 2008 | IBM ThinkPad 600X Notebook
I need to reinstall windows on packard bell imedia 5106
 Because you have a packard bell, I would assume this is a much older system.  You would have to put Windows 98 on it I presume unless you have enough memory to do XP.  Either way you will need one of the Windows CDs to load the software... I ve seen Win98 on Ebay for $50. Once you have the software, you will need a boot disk.. You can download this off the Internet.  What this boot disk does, is it loads the utilities that you need like to format the hard drive and it will also load the cd rom drivers so you can use your cd rom and install windows from the cd... Load the boot disk and once its loaded you can use the format command.  At the C Prompt, type     format C:     It will erase the Hard Drive. Once completed,  Reboot the computer with the boot disk still in. When it gets done you can install Windows. Most times it will assign the cd rom drive a letter. Usually D or E.   When it comes up type    E:\Setup This should start your install.                                                              Joe < Data Miner >
Oct 30, 2008 | Computers & Internet
Old 95 computer
well you have to get the cd you may have to buy it or get that from somebody
Dec 27, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
