Question about Philips 32PF5320A 32 in. LCD Television
No sound I have no sound at all...does it have a fuse for speakers?
  • Ragg01 Apr 05, 2008
    This is for a phillips 32pf5320/28 flat t.v.
  • Ragg01 Apr 06, 2008
    lol.....not on mute.....bought it with no sound...it works with surround hooked up only.
Have you got it on "Mute"?
Posted on Apr 05, 2008
Rear speakers have no sound
No speakers are not fused.. It is most likely a speaker wire that has gone to ground so they would have to be traced to each speaker to see if you can find the short
Jan 10, 2014 | 2007 Toyota Camry
Low Frequency Effect
Hi
in this case the audio is good but the output speaker is not working because you have blown fuse at the amplifier section thats why cant hear the sounds... check the amplifier section then check the fuse speaker protector.. replace a new fuses with the same rate....
Thanks....
Jan 24, 2008 | RCA RT2500 System
I cant get any sound from my speakers only the subwoofer will work
Klipsch, usually fuse the speakers. look at the back of your speaker to see if there is a fuse holder, if not, it may be internal and if there is a panel you can take off, do that and look inside for a fuse and check it with a volt/ohm meter if its blown replace it with same value fuse. Aother way you can check to see if the speakers still work is to take a 9 volt battery and touch the terminals of the battery to the terminals of the speaker, if you hear a clicking sound or better yet can see the speaker move in or out the the speaker is good and the problem is elsewhere in your system. if both speakers don't work I would first suspect the fuse in the speakers. you could also try hooking up different speakers to your amp and see if those work, one last thing, plug in some headphones, if they work you will know that at least that part of your amp works.
Mar 13, 2011 | Klipsch KL-7502-THX Speaker System
The horn works but not the 15" you can hear the
Hi, problem can be solved. The problem can be from two places,
From the speaker and,
also the cross over.
I might be from the speaker if the wire connected from the cross over inside the speaker has cut or has removed.,it can make the speaker (15),not to make any sound..
The cross over might also be the fault too. The cross over is located inside the speaker and it makes the 15 speaker makes sound..
'There are capacitors on the crossover that control and makes the 15 speaker make sound.If the capacitor gets damaged it can make the sound stop. Also you will need to check the fuse inside the speaker, you will find the fuse on the cross over of the speaker.
Troubleshoot the above, and problem solved,...
Hope that helped..
Thanks fro using fixya.....
Oct 29, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Where r the fuses for the speakers
RADIO FUSE IS SPEAKER FUSE.IF GETTING NO SOUND RADIO SOUND CHECK SPEAKERS FADE AND BALANCE CONTROLS.
Oct 08, 2010 | 2000 Mercedes-Benz S-Class
I was listening to music loud on my 5.1 speakers and they cut out. No sound, no lights to indicate it's even on. I did notice the fuse but took it out and it looks fine.
What has most likely happened, is that the speakers were over-powered and could not deal with the amount of sound. Or the other thing that would have happened, is that the fuse blew. If either of these is the case, the only solutiono is to purchase a new fuse for the speakers,(make sure you notice the voltage of the fuse - (find that on the original fuse itself.))
And after that, don't listenm to music that loudly again!
Aug 06, 2010 | Dell 5650 Computer Speakers
My speakers sound is no longer perfect
Blown fuses are SOLID dead circuits, not bad sound.
Try different speakers first. If the electronics was cooked it would probably be silent.
May 18, 2010 | Polk Audio RTi100 Main / Stereo Speaker
Speakers dead
check for individual speaker resistance. or in the dividing network for some burn fuse or coil.
Apr 05, 2010 | Logitech Z-2300 Computer Speakers
My speakers were on but would not play any sound. I removed the fuse and then put it back in and now the speakers will not turn on
put you fuse back correctly and check fuse is ok or not and install your sound driver's if they are installed so go to control panel and then go to sound option and click on advance and chose your speaker like 5.1,4.1 or any other you know which 1 and then click apply and then check your sound that's all
Nov 18, 2009 | Audio Players & Recorders
Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Oct 08, 2008 | Bose 151 Main / Stereo Speaker
Philips 32PF5320A 32 in. LCD Television Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
