Question about HP LaserJet 3330 All-In-One Printer
HP LASER JET 3330
THE MACHINE IS USED ONLY AS A COPIER. OFTEN THE MACHINE MAKES A RECRRING GRINDING NOISE(WHILE IDLE) AND THEN DISPLAYS MESSAGE "SCANNER ERROR" "POWER OFF"
  • 2 more comments
  • mmedhat May 07, 2008
    THE MACHINE MAKES A RECRRING GRINDING NOISE(WHILE IDLE) AND THEN DISPLAYS MESSAGE "SCANNER ERROR" "POWER OFF",
    if restart from power on/off , the occur agian and i can't use the machine for any function.
  • Genigen May 08, 2008
    Scanner resets constantly...never stops until I turn the machine off (unplugging is the only way to turn it off). I have to wait at least 1 minute before restarting. It will be quiet until I set somthing in the feeder to copy or try to copy something...or just don't do anything...it has a mind of its own! I have tried turning it off all night and nothing...the problem is getting much worse. I removed the little glass on the left side to reposition the belt, but it is constantly moving....do I need to turn my machine off and wait for it to stop resetting? I don't see how that will help?
  • darholland Jul 19, 2008
    After plugging it back in, it continually makes a grinding sound which appears to come from the scanner.
  • Anonymous Mar 25, 2014
    There is a grating (grinding sound when I turn the machine on. can I fix it?
    Problem Solver:
  • 9 Answers
Sounds like the scanner bulb mate. There is a post on here already about how to fix the scanner bulb problem.
Hope you fix it
Posted on Apr 22, 2008
  • 5 Answers
If you are a visual learner like me hopefully this You Tube video will help (I fixed mine using it). Here's how to clean the mirrors of the scanner
https://www.youtube.com/watch?v=lqG_nmi3vC4
Posted on Jan 24, 2015
Hello! I have got a 6 year old HP laserjet 3330 all in one laserjet printer.As soon as I switch it on, it makes a grinding noise. I think it comes from the a4 sheet feeder area. I tried lubricating...
I don't think the toner cartridge is amiss here. I think that on hp printers that are older, such as yours, the rubber feed rollers shrink and cause feed problems, over time.
Feb 09, 2011 | HP LaserJet 3330 All-In-One Printer
Hp 3330 laser jet memory low error when faxing
1)Press ENTER/MENU
2)Simultaneously PRESS then RELEASE * then # to enter Developers Reset(This is a soft reset. No loss of data or configuration settings).
3) Press < or > button until the message REINIT FFS appears on the second line of the control panel.
4) Press MENU/ENTER.
5)Takes about 2.5 minutes.
6) When READY appears on display press CANCEL to exit.
Apr 02, 2010 | HP LaserJet 3330 All-In-One Printer
Hp laserjet 3330 gears on right side grinding after print
The most common problem with grinding is from compacted toner. Try changing the toner cartridge.
Aug 26, 2009 | Office Equipment & Supplies
Hp laser jet 3330 will not reset with acquired instructions and bulb warming message stays on.......i've tried to unplug unit....stays the same. cancel button also stays lit
You need to take apart the top and clean the scanner bulb and mirrors, if cleaning does not help then you need a new scan assembly. Usually costs more than a new machine.
Jul 14, 2009 | HP LaserJet 3330 All-In-One Printer
Makes a grinding noise near the drum. Copier works, but makes a "gear-grinding" noise near the drum area. Can't tell what's doing it.
Un load the drum unit, check the drum/s gear, is it wear off, if so change it along with the drum's drive gear at machine base, check also the gears of developing unit
Jun 29, 2009 | Sharp AL-1540CS All-In-One Laser Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
HP Laser Jet 3300 constant noise
I had the same problem. After updating a hp firmware, so far so good. The noise is gone.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=66367&prodTypeId=18972&prodSeriesId
=66359&swLang=8&taskId=135&swEnvOID=54
That is the link for the 3330. It is under the downloads section and is at the bottom. They refer to it as firmware
Nov 08, 2007 | HP LaserJet 3300 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
365 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
