SOURCE: 1993 190e 2.6 transmission problem
I have a 93 MB 2.6 190E . went to junkyard, got same tranny, spent 500 bucks to replace. Drives fine. No metal shavings on mine either but changed tranny, ok.
SOURCE: Automatic Transmission shifts late and rough after warm
If it has over 60000 miles it may need a transmission service, which includes a filter and fluid change, fluid may look fine but if filter is clogged and not picking up fluid fast enough when u give it gas the pump spins faster and forces fluid thru to shift, more fluid is needed to shift into higher gear.than to drive
SOURCE: automatic transmission not shifting into 3rd or 4th
call a dealer and they will tell you you are suppose to change your transmission fluid every 2 years or 30,000miles but if you was carrying this much load you may have over heated the transmission so I would shop around and get a good deal at a transmission place where they can replace the filter and the fluid and adjust the bands on the transmission if needed
SOURCE: Bizarre shifting pattern 1984 Mercedes 300D automatic
Hello, The adjust of your t/v cable, not kickdown cable, and the operation of the vacuum controller at the rear of injection pump, and the modulator, is critical for this car to get a good shift.
Put you cable back on, adjust it so that when you have wide open throttle, the cable does not have any slack. Check the black vacuum line by the oil filter housing that goes to the modulator to see if it has vacuum. It should have about 10-15" vacuum and as you increase engine speed it should drop. If you get close to this, the trans should shift ok. If you cannot get vacuum at the modulator line, you need to ck vacuum supply, valve at rear of injection pump, hose routing, etc.
If the B2 piston failed, it would be difficult to move car or slip badly. Also, take into mind that at the bottom of your accelerator pedal stroke is a kickdown switch.
If you accomplish what I instructed, you will probably get a decent shift.
If you find this information to be correct would you please enter a "fixya" rating.
Thanks, Gator241
SOURCE: Rough shifting automatic transmission on Honda Accord from 1st to 2nd gear
it has a problem with the second gear drum it cracks and does not fully engauge the n shifts to 3rd ..many honda owners also learn the 8 bucks a quart is the only fluid to pour in a honda..but remember 3 qaurts per drain and fill the tranny holds 7q ....it will take a case to do a drain flush...a high pressure flush will ruin a automatic tranny with alot of miles or metal deposits floating around inside..DRAIN AND FILL 3 QUARTS AT A TIME NO GASKET NEEDED ITS BUILT AND DESIGNED LIKE A MANUAL TRANNY
RPO | Trans Name | 1st | 2nd | 3rd |
MNK | Allison 1000 | |||
MNZ | Allison 1000 | |||
MW7 | Allison 1000 | |||
MYB | ||||
MYC |
M74 | Allison 1000 | |||
M22 | 5L50-E | |||
M82 | 5L40-E | |||
MTW | Allison 2400 | |||
MX4 | Allison 2000 | |||
MX5 | 5L40-E with PTU* | |||
MV3 | 5L50-E with PTU* |
M30 | 4L60-E | |||
M32 | 4L60-E HD | |||
M32 | 4L65-E | |||
M33 | 4L60-E Hybrid | |||
M41 | 4L30-E | |||
M70 | 4L70-E Super Duty | |||
M99 | 2ML70 2-mode Hybrid* | |||
MD8 | ||||
ML4 | 4L30-E | |||
MN8 | 4L80-E HD | |||
MN8 | 4L85-E | |||
MT1 | 4L80-E | |||
MW9 | HM 200-4R |
M40 | ||||
M41 | ||||
M65 | ||||
MD2 | ||||
MD3 | HM-180 | |||
HM-200C | ||||
HM-350 | ||||
HM-400 |
MH2 | ||||
MH4 | ||||
MH6 | 6T75 (AWD) | |||
MH7 | ||||
MH8 | ||||
MY9 | 6T75 (AWD) |
Aisin-AW 55-51LE | ||||
M09 | Aisin-AW AF33-5 | |||
M43 | Aisin-AW AF23-5 | |||
M45 | Aisin-AW AF33-5 | |||
M98 | AF33-5 | |||
MJ7 | Honda 5AT | |||
MJ8 | Honda 5AT w/PTU* | |||
MLS | Aisin 50-40E | |||
MU3 | Saab 76.5mm |
MLQ | Aisin 81-40LE | |||
Aisin ZF 4HP 16 | ||||
HM 325-4L | ||||
Jatco JF405-E | ||||
M10 | Jatco JF403-E | |||
M13 | 4T60-E HD | |||
M13 | 4T60-E | |||
M15 | 4T65E | |||
M45 | Aisin-AW AF33 | |||
M57 | A245-E | |||
M76 | 4T65E with PTU* | |||
MD7 | 4T65E | |||
ME7 | 4T45-E BAS Hybrid | |||
ME8 | ||||
ME9 | ||||
MH1 | 4T80-E | |||
MN3 | 4T65E | |||
MN4 | 4T40/45-E | |||
MN5 | 4T45-E | |||
MN7 | 4T65E HD | |||
MS7 | A240-E | |||
MU4 | A246-E | |||
MU5 | U341-F |
M60 | GEO Metro | |||
MB3 | A131L | |||
MD9 | ||||
MX1 | A131L | |||
GEO Storm | ||||
HM-425 |
M10 | Tremec 85mm | |||
M12 | Tremec T56 | |||
ML6 | ZF S6-650 | |||
ML9 | ZF S6-40 | |||
MM6 | Tremec T56 | |||
MV1 | Aisin 85mm | |||
MV5 | Aisin D173 AY6 | |||
MV6 | Aisin 85mm | |||
MZ6 | Tremec 85mm |
M35 | Getrag 260 | |||
M35 | Getrag 260 (2003-2004 Cadillac CTS) | |||
M49 | BW 5spd | |||
M50 | ||||
M59 | GEO Tracker | |||
M86 | Getrag F23 75mm | |||
M94 | Getrag F23 | |||
M96 | Tremec 109mm | |||
MA5 | Aisin AR5 82mm | |||
MG3 | Getrag F23 | |||
MG5 | ||||
M50 | ||||
M51 | ||||
MH3 | Tremec T-5 | |||
MK5 | C59 | |||
ML2 | Tremec T-5 | |||
ML3 | Tremec T-5 | |||
MT8 | ||||
MU3 | Saab F25 | |||
MW2 | ||||
MW3 | NV4500 109mm | |||
TR-3450 | ||||
TR-4050 | ||||
TR-4050 | ||||
2007 Chevrolet Optra and Spark (Trans code Y4A) | ||||
2007 Chevrolet Optra and Spark (Trans code Y4M) |
M20 | HM-117 | |||
M73 | Isuzu | |||
MC0 | Getrag | |||
MC9 | ||||
MY6 | NP260 |
MT2 | Opel F40 83mm | |||
MU9 | Opel F40 83mm | |||
MTN | Toyota C60 |
D-16 (2005-2008 Chevrolet Aveo 1.4 DOHC / 1.5L) | ||||
D-16 (2005-2008 Chevrolet Aveo 1.4 SOHC) | ||||
Y4A (2007 Pontiac Matiz) | ||||
YM4 (2005-2007 Chevrolet Aveo) | ||||
D-20 (2005-2007 Chevrolet Epica) | ||||
L73 | Pontiac LeMans F16 | |||
M42 | Geo Metro | |||
M43 | AF23 | |||
M49 | BW 5spd | |||
M58 | Geo Metro | |||
M79 | LeMans F13 | |||
M86 | Getrag F23 (5T45MI) | |||
M98 | Aisin 55-51E | |||
MB4 | Geo Prizm 1.8L | |||
MB5 | Geo Prizm | |||
MFB | 2008 Chevrolet Epica 5-Speed S/R (D24) | |||
MFN | 2008 Chevrolet Epica 5-Speed S/R (D33) | |||
MG1 | HM-282 | |||
MG2 | HM-282 | |||
MJ1 | Isuzu | |||
MK7 | Isuzu | |||
MLM | Y4M (2008 Chevrolet Aveo 1.6 DOHC) | |||
MR3 | Isuzu | |||
MV2 | Chevrolet Sprint | |||
MY7 | Early J-car |
RPO | Trans Name | Lowest | Highest |
M83 | V20-E | ||
M75 | V25-E | ||
M16 | V25-E AWD |
