Question about Sony Cyber-shot DSC-W55 Digital Camera
Lens wont go back in help
I dropped my camera on my table and now the lens wont go back in.. is there anything i can do?
  • 104 Answers
U dont try by force, ur lens unit dislocated this is repairable contact any local repairer
Posted on Apr 05, 2008
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Casio xilim s770..problem : camera turns ..lens
hi,you have problem in lens gear that why you heard a weird noise or what you said buzzes.sometimes the cuase of excessive force or impact from the lens it will damage the gear or misallign and not only felldown or drop will damage the camera. Its also affect the sand or dust goes inside of your lens thats whay the gear not work properly.
if you have knowledge repairing electronic its better you need to check the lens gear,cable and len barrel if all of this are ok. if not bring to service center for estimation first before you proceed to repair.
godd luck and thank you my friend
Jul 18, 2010 | Casio EXILIM Card EX-S770 Digital Camera
My problem is that the lens has come out and will not go back in. it tells me lens error but wont do anything else
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jul 14, 2010 | Nikon COOLPIX S200 Digital Camera
Lens error, restart camera
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
May 26, 2010 | Canon PowerShot SD1000 Digital Camera
Zoom error, Fujifilm J150w
I just pulled apart the camera, everything inside was intact. No cogs broken. couldnt find anything to fix (not a camera expert by the way).
In desperation even put some WD40 on the lens barrel - still no luck.
Camera turns on - barrel is stuck out. Wont zoom, wont go back in and wont take a photo.
Daughter's camera and she says she didnt drop it but just saw it on her desk with the lens out...
Would be good if someone could shed some light on the problem.
Jul 05, 2009 | Fujitsu Cameras
Lens is stuck
Time for a new camera, the cost of repair is way beyond value of this camera.
Jul 01, 2009 | Kodak EasyShare M863 Digital Camera
Hi my son dropped my digital camera while the lens was extended and now it wont retract and it says zoom error also the shutter wont open fully or close, the lens is at a slight angle and wont budge do i...
Hi
It helps to know the make and model of the camera, some cameras the lens is too fragile and we have never been able to repair them. Other models we have had a great deal of success repairing them. (Google: darntoothysam)
One trick you can try... at your own RISK... is to put the camera lens on the edge of a table and gently but firmly push it back towards the middle and try to get it to CLICK back into place. There are three small metal pins inside the lens barrel and these pins ride in grooves in the inside of the lens, this makes the lens move in and out... If your lens is at an angle, at least one pin has jumped out of its groove.
Put the SIDE of the lens (NOT the flat front of the lens, the rounded side) on the edge of the table with the camera body not touching anything. Push the lens back towards being straight again and it will either click back into place or it wont. Even if it does it may not work, or you may damage the lens further.
If you don't want to try this or if you find you need the lens replaced, we can help, we are an affordable digital camera repair business, feel free to check us out and let us know if we can help.
Good luck from Darntoothysam com
Thomas
Oct 10, 2008 | Cameras
Pink polaroid i631 camera
Try to put the lense back in, take it to a store (like best buy, circuit city, radio shack) they might fix it for a small price
May 18, 2008 | Polaroid i735 Digital Camera
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
