Hp laptop wont restart
My hp laptop went into hybernate and when i tried to turn it back on the laptop turned on and immediately ahut down. Wheni try to turn it back on all that happens is the windows startup menu comes on to restart or reboot then it goes to a black screen with a flashing light in the top left of the screen. what do i do please help
  • Anonymous May 21, 2008
    samething here,i even reformat my laptop and still same issue,i even update bios firmware and also update the video card firmware
  • anaespak May 08, 2009
    when i put the laptop to sleep or shut down it does not restart and I have to disconnect battery and wait for several hours before it restarts again.During this period on/off button stops functioning and I have to disconnect battery to shut it down.
Google translate sucks so so so so bad
Posted on Aug 24, 2008
  • 35 Answers
Please connect your laptop to external monitor.
if it works with external monitor, then the problem is with your laptop monitor driver.if that is the case, then re-install laptop monitor drivers.
if it doesn't work even with the external monitor, then re-install graphic card drivers.
Posted on Apr 05, 2008
SOURCE:
My hp compaq nc4400 does not detect its hdd
Hi
you could try this it sometimes work
turn off laptop and unplug power cord
turn laptop upside down
find the panel underneath that holds the hard drive usually 2 screws
remove panel and remove the hard drive
If you are not sure how to remove the hard drive ( not difficult )
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01884372&printver=true
turn laptop up correct way and try to restart laptop
it wont start up because you have removed the hard drive
now switch off again
turn upside down again
replace the hard drive
replace the panel
turn up correct way
and try to restart the laptop again
if this dont work
now turn off and on again pressing the F8 tab a few times to see if it takes you into repair options
and try the back to last known good configurations
or try some of the other repair options
hope you get it sorted
many thanks
Mar 22, 2011 | HP Compaq nc4400 Notebook
When trying to turn on my laptop, I get the above status message and it says missing registry files. Why is this. My laptop battery doesnt chartge either.
If you are running either Vista or Win7, when someone tries to open a fresh user name, this will cause registry errors as will deleting programmes without uninstalling or just generaly closing the laptop without shutting it down. Letting it go into hybernation/sleep mode and the battery going totally flat then restarting the laptop without coming first out of hybernation, may cause this sort of problem.
There are a few utilities that will fix this problem available on the net, PC Tools, Norton Utilities to name just two.
Hope you clear your errors.
Dec 30, 2010 | Computers & Internet
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Nov 19, 2010 | HP Computers & Internet
IBM T23 Laptop went into hybernation when battery
Are you going to use hyernation again...it takes lots of space and may freez your computer if you do not have a space use safe start and look at c: and see how big is the hiberfil.sys do not delet it if you are going to use it again if not try to disconect. temp. by typing "powercfg -h on"
Hope that work for you please post your outcome
Sep 13, 2009 | IBM ThinkPad T23 2647 Notebook
My lenovo laptop after resuming says it is hybernating and continues to shoe the same for hours together .it hags on. it is not starting again pl let me know how to start. i am new to laptops. ihave been...
Install the operating system again. I think your operating system is corrupted. Or it has shut down improperly while installing updates.
So you have to install os again.
cheers
Jul 10, 2009 | CMB T43 750 Notebook
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
Wont turn on
At this situation we can try power drain.
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
That should resolve the issue. If the issue persists, then the only option is service center.
Jun 08, 2008 | HP Compaq Presario C500t Notebook
My Toshiba A105 went into hybernation and will not come back up.......................
unplug the laptop, remove the battery, wait 15seconds, put the battery back, plug it back in.
If it doesnt work after this.
Drop me a line and il give you more assitance.
Mar 17, 2008 | Toshiba Satellite A105 Notebook
My A105 Toshiba Satelliet is stuck in hybernation and will not come back on
hi dear
oke ...try to remove the battery from your notebook, try on with only adaptor
after normal you can put your battere again
thnks
cropp
Mar 17, 2008 | Toshiba Tecra 8100 Notebook
Random Hibernation
this sounds like power settings options.
what i can suggest now is that......................
go to the Power Options in the Control Panel and do the following.
  • first uncheck the hibernate option on the hibernate tab
  • use your computer and see if the problem re-appears, go to the control panel and on the power option, select Never to all options when using battery or ac power.
cheers...............
Oct 24, 2007 | Sony VAIO VGN-N130G/W Notebook
Open Questions:
Computers & Internet Logo
666 people viewed this question
Ekse
Marvin
Marvin
