Question about Yamaha HTR-5650 Receiver
Minimal sound from the sub, all other speakers working fine
Old sub blows fuses i think its cuz the power went out in the house 1 time, anyway i removed and replaced the sub with a new one but i didnt get much sound. could only hear the sub when my ear was up close to it. even turned up all the way. i thought it was the sub so i returned it and switched it. stil the same tho. how come all the other speakers work fine? i'm goin crazy here. is my yamaha also toast from the power outtage? time for a new one? i hope not. thanks for ur time.
    Problem Solver:
  • 10 Answers
You should try to increase with remote of your yamaha the sound level for sub.In my Pioneer receiver I can increase level from minus 10 to plus 10 DB
Posted on Jun 07, 2008
2 Suggested Answers
SOURCE:
  • 151 Answers
SOURCE: minimal sound from subwoofer
MAKE SHURE YOU HAVE TOLD THE AMP YOU HAVE A SUB IN THE SET UP MENU UNDER SPEAKER SETTINGS.
IFF YOU ARE USEING SMALL SPEAKERS THEN SET THIS IN THE MENU AND OUT PUT BASS 2 SUB ONLY ,SET XOVER ON AMP IFF U CAN 2 120HTZ, ALSO CHECK THAT YOU HAVE THE SUB CABLE PLUGED INTO SUB OUT ON BACK OF YOUR AMP ,AND NOT THE 6 CHANNEL INPUT.
HOPE THIS HELPS.
CABLE GUY.
Posted on May 20, 2008
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
I put a new radio in my car and now it wont start 1190 toyota
Did you in stall it your self ? if so make sure you didnt blow fuses and check the connections make sure you are getting power and if you put subs and power amp and stuff like that make sure you have enough battery power to power everything if not the car wont even turn at all cuz the juice is working on its own to start the radio. check also you didnt cut any wires while doing so and if you didnt install it your self and took it in then take it back something went wrong maybe....
Dec 02, 2009 | 2001 Chevrolet Venture
New dryer keep blowing 30 amp fuses
your problem (especially if you are using screw-in "plug fuses") i.e. BUSS fuses and cartridge fuses they get hot and with time the insulating disc that insulates hot from neutral (grnd) breaks down and with dryer current draw it arcs over and in summer its more humid which contributes to moisture,have a new sub(pony) panel if you have no room for another 240volt circuit in your main panel,that should cure your trouble
Jul 19, 2009 | LG DLE5955 Dryer
Problem with subs and amp
I would first suggest un-hooking the subs, and hooking them up to another known good radio other than the one its hooked to now. Just to make sure you didnt blow the speakers. What is the wattage of the subs? Then if the speakers do work I would hook them up bypassing the amp just to see if the problem exist before or after. Come back after doing this. Thanks
Jul 05, 2009 | Car Audio & Video
Samsung hcm4215w keeps blowing conv resistors
Look Do this
Replace your STK's
I dont trust them any more after all that info, wow
anyway
replace them
and yes you need Rz123 and Rz124 to be 3.9Ohm @ 2w don't sub.
Now also order a, 3.5a pico fuse for location Fd102s.
regards,
hope this helps you.
daniel.
Jan 11, 2009 | Samsung HCM4215W 42" Rear Projection...
Tv keeps blowing fuses when its plugged in...
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
Jan 06, 2009 | Televison & Video
My ILO tv wont come on.
Sounds like you probably should have had a surge protector, Kind of an expensive lesson to learn. 20 or 30 bucks for a couple thousand dollar pay off, but anyway, learn from the mistake and put your computer and stuff on one. Well anyway, most TV's will have a fuse in the main power supply that you can order from allied electronics, or your local radio shack. Hopefully you are lucky and after you replace the fuse the TV comes right back to life, if not, it is an excellent excuse to make a trip to your local best buy. =) Hope this helps,  Funnyguyjake
Dec 31, 2008 | iLO LCT32HA36 Television
Minimal sound from subwoofer
HOPE THIS HELPS.
CABLE GUY.
Apr 05, 2008 | Yamaha HTR-5650 Receiver
Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Onkyo SKW-200 Subwoofer
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Yamaha HTR-5650 Receiver Logo
67 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
