Question about Yamaha RX-V661 Receiver
No sound with cable tv- AM/FM works ok
House guests must have done something with the remote because I can no longer get my surround sound to play with what's on the screen
  • 5 more comments
  • darnie Apr 05, 2008
    the tuner setting produces sound, the DVT/CBL does not. Could the settings for the tv have been altered with the tv remote. Its on component 1 . Darnie
    unfortunately my computer is not near my tv so I have to go into the other room and try something. I would consider myself not very intuitive with this stuff. The Visio remote has all sorts of settings when I push INPUT. "TV,AV1,AV2,Component 1,Component 2, RGB,HDMI1,HDMI2". It's on Component 1.The "menu" button brings up various controls for the video i.e. vol, balance etc.When the speaker buttons A and B are on are the buttons pushed in ????I would expect so . I have outside speakers that were working last night on the "B" setting but when I push the "A" there is no sound inside the room. : ( Helllppp !darnie
    you've got to be more specific than "check the settings" what am I checking them for ? what should they be ? there is no signal issue from COX the TV sound is working. It's the tuner settings that are fouled up. I am looking at the tv remote . there is a line of buttons that are " TV AV Component HDMI Does that help at all? Darnie
    I'm wondering if I just take the batteries out of the remotes -- will they remember the settings( whatever they are )) Darnie
    none of these things work darnie
    problem still exists. suggestions have not been helpful. I don't have a "K" button !! or I can't seem to find one. My set is on DTV/Cable. the ear phones are not plugged in. I have it on auto. Your assistance has not been helpful so far. Darnie
  • darnie Apr 06, 2008
    the speakers are not "busted" . If you read the comments I have made , I told you that the speakers work with the AM/FM setting but NOT with the DTV/CABLE setting. I would prefer a refund and not continue with this any longer. FDZ
  • 871 Answers
In regards to what Psionics said,
double check the settings of your AV,channels setup and cable box.
im sure that your guests did not physically mess up your tv and speakers right? so just double check the input and output wirings for everything there on your tv.
one probable cause maybe the remote has a switch feature which you can control avr, tv, receivers a.k.a. universal. check also the sound setup for the tv as it may have been changed to stereo or mono and surround mix...
feel free to post what happens as we will try to use the answer for your problem to our database.
thanks for using fixya
Posted on Apr 05, 2008
  • 3 more comments
  • earl norman llanera
    earl norman llanera Apr 05, 2008
    hey danie,
    thanks for that. now its clearer.
    yes, it could be from the tv since your using a component afterall.
    please do check also the settings on the component just to be sure.
    post back
    ok darnie, thanks for that.
    dont worry since you mentioned that your using component1. under component 1, use also mention that you are using A & B right. Aplatform sounds but B platform does not. try to check the balance for the audio.
    and in your remote, you can try to push just once but not "push-in" the A and B. just do try and hopefully something will happen.
    post back.
    ok darnie. sorry for that,
    what i mean is, try to check your remote, press component. then when youve already pressed component, something will appear on your tv right? from there, you can try to push the A & B. please post what happens after pressing .
    yup! try to change the batteries first.
    earl norman llanera Apr 06, 2008
    well darnie,
    since youve tried doing this and that. maybe the speakers of your A platform are busted.
  • 236 Answers
First, check all the connections to the receiver.. Make sure everything is plugged in where it should be.. Also make sure, that when you are on TV/CABLE that the surround sound is selected and that "headphones" is not.. Also check any other modes that may have been changed, (IE digital input, 5.1 channel, etc...)
  • 6 more comments
  • Dave MacPhee
    Dave MacPhee Apr 05, 2008
    press the operation mode selector (K) button and make sure the mode is set to DTV/CABLE and not PHONO
  • Dave MacPhee
    Sorry, make sure the TV mode is set to DTV/CABLE
  • Dave MacPhee
    Try puting it to TV
  • Dave MacPhee
    how about the receiver remote... What options do you have their?
  • Dave MacPhee
    * there
  • Dave MacPhee
    Dave MacPhee Apr 06, 2008
    Try setting the audio input jack select to "AUTO", also make sure the front speakers are selected by pressing (1)SPEAKERS on the front panel (you may have to press more than once)
  • Dave MacPhee
    Also try setting “SUR. L/R SP” to “SML” or “LRG”. or Press (15)STRAIGHT on the front panel so that
    “STRAIGHT” disappears from the front panel
    display.
  • Dave MacPhee
    Another thought, if you go into the Yamaha menu, and select "input menu" and then select I/O assignment, what is listed there?
SOURCE:
I've had a Pioneer receiver hooked up to have surround sound and I have used this to play music throughout my house in bedrooms, to play Blu Ray and TV which have all worked fine. I had a guest in my home...
go through the input modes its one of them leave it each mode on for 30 seconds what output do you have for audio on the blueray. It can also be setting for audio from blueray was turned off swich to fiberoptec
Mar 04, 2015 | Pioneer Audio Players & Recorders
PS3 no longer plays Bluray discs in surround sound
check your blueray settings updates can reset them sometimes.
Apr 23, 2009 | Sony Playstation 3 (PS3) Console
Black Rectangle Box appears shortly after turning on TV
That is the PIP (picture in picture) setting, on the TV's remote control. locate the button marked PIP and press the button, it should clear the little box.
Apr 04, 2017 | TruTech PVS31170S1W 17 in. LCD Television
Surround Sound Not Playing For TV Programs
Greetings jdm12,
I can understand your problem, I have some what of the same issues with my home theater setup when watching events. One of the only suggestions I can make is adjusting the "Dolby Pro Logic II Mode". After reviewing your owners manual it appears you should be able to change the mode by pressing the PL II Mode button found in the lower keypad on your remote. It appears the options you should have are Music - Cinema - Pro Logic - Matrix - Stereo. You may want to try Music or Stereo when watching your events. In Stereo setting it should provide sound out of the front speakers and sub-woofer only. In Music, there are more processing that is done so you could hear more then just the front speakers.
I hope this makes your next your next PPV Party a big hit!
Jon
Go Ahead. Use Us.
Jun 17, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Remote Code
THE SURROUND SOUND REMOTE THAT CAME WITH MINE IS AD-100MTRS . for the surround sound system for the ad-1100s dvd palyer.. my surround sound no longer works. i do havethis remote still.. where are you located.
e-mail me back at:
[email protected]
use suject-remote for surround sound system.
Feb 08, 2008 | Aspire Digital AD-1100S DVD Player
I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Feb 05, 2008 | Marantz SR-5200 Receiver
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Yamaha RX-V661 Receiver Logo
74 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
