Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
LID SWITCH ON WASHER REPLACE.
I figured out the reason the washer would not go to spin cycle was that after inspection the lid switch is broken. I figured out were the plug is but cant see it to unplug it. I,m assuming the top need to come off but not sure how to do that. any advice. Ok so my model number doesnt come up on this product but iI know the thing exist so I will pick the next close one. the model # is LSQ8543JQ0 its a whirlpool top load ultimate care II
  • Anonymous Apr 10, 2008
    Whirlpool model LSQ9010KT0...agitates even with lid open. Will not rinse or spin. Cannot get lid to come off....is there a secret with this model? Water presently in machine.....Thks in advance....
  • mcco 396 Apr 10, 2008
    Whirlpool model LSQ9010KT0 Type II....machine agitates even with the lid open.....will not rinse or spin....tried removing top to check lid switch but could not remove....is there a secret with this model.....thks in advance
  • 3 Answers
TEMPORARY FIX for model # LSQ8200HQO (perhaps, other models as well) until you can tear the thing apart: DUCT TAPE. One drawback - you'll have to leave the lid open, tape the lid switch on the outside *away* from the tub. The wires on the model listed are long enough to allow you to do this.
Thanks for helping me figure out what the problem was. Tearing apart will have to wait until Monday ... RUSH CONCERT tomorrow night!!!
Posted on Apr 20, 2008
On the Ultimate Care II, for a broken lid switch, here is a band-aid solution to get you by. I've been doing it for a year now. Close the lid, place the heal of your hands down on the lid about 2/3 of the way back near the left edge. Then press down on it with your weight like you are giving it CPR. Once usually does it! If you open the lid for any reason, you have to do it again. I get it all full of water and soap, ready to wash, close it, and give it a shove. Good luck!
Renee
Posted on Apr 13, 2008
  • 725 Answers
Hay Flyman
the whole cabinet comes off as one unit .. if it broken not just unpluged you will need a new one... Part # 3949247
LMK if I can help
krazytech
Posted on Apr 05, 2008
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore machine stopped spin. Checked the
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
If you have questions, please let me know. I hope this helps you.
Key Symptoms:
If the Motor Coupling were bad the washer will not agitate or spin, but WILL drain.
If the Lid Switch fails, the washer will fill, but stop before the spin cycle and WILL NOT drain.
Aug 23, 2009 | Washing Machines
Spin Cycle Not Working
the most common problem when this occurs is the lid switch has broken inspect it if not click when lid is closed replace the switch you see if you can get local it saves some shipping cost unless they are outragious then order on line
Aug 07, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool top loading washer will not spin or drain. It does agitate but it will not spin. In trying to look at the lid switch, the striker piece came off. Not sure if that is the original trouble. ...
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Jul 18, 2009 | Whirlpool WFW8300SW
Won't spin, won't drain
Hi...
If your washer does not drain, you need to check this:
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
If it does not spin check also this:
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Our washer won't agitate nor will it spin properly what's the problem I have a kenmore washer and it is doing the same thing. How do you get the front off of the washer?
Dear Customer
please perform the following checks
Please rate this,Thank u
Dec 17, 2008 | Kenmore Elite 21086
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LSR7133KQ0 no pumpout, rinse, or spin.
NO...the problem you are describing are the typical symptoms of a lid switch malfunction. The lid switch shuts the washer off when you open the lid while the drum is spinning. This is a safety feature to prevent injury from moving parts if you decide to add a garment or stick your hands in the tub for some reason while it is in operation. On some model Whirpool's the washer WILL work initially for the wash cycle, then stop when it gets to the rinse cycle. I would recommend you check your lid switch to make it is not loose or broken. Your washer is also equipped with a lid strike (a small plastic piece on the lid that activates the switch) make sure it is not broken off or missing. This will give the same symptoms of a broken lid switch.
If you require a replacement switch, they can be ordered on line at searspartsdirect.com, or you can go to your nearest appliance parts retailer. The part number for the switch is 3949247. The lid strike (if required) is part number 358684. If you need instructions on how to replace the lid switch, you can use this link if you like:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I don't know how savvy you are, so I thought I would add the instructions just in case. I hope you find all this information helpful. Let me know if you require additional assistance.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
383 people viewed this question
Dan Webster
Dan Webster
Sal De
