Playing my iTouch on my Samsung HDTV
I have a Samsung HDTV and Samsung HT-X70 Home Theater system. I bought this home theater system because one of the features was a USB In port on the front with a Audio In next to it. It came with the cable to connect an iPod - iPod connection on one end which splits into two connections on the other end - audio plug and a USB plug. When I plug them both in I only get sound out of the Home Theater. The Home Theater reads USB Error and my TV screen reads USB INIT Failed. So, I have my iTouch pluged into the AUX 1 & USB connections in the front with the supplied cable and the video out on the back of the Home Theater to the Video in on my TV.
Should I be able to play my iTouch through the Samsung HT-X70 unit? Please advise at [email protected]
  • cold_carnage Dec 05, 2008
    I have a very similar problem in that the Samsung HDTV (750 series) has a USB port. When I plug in my iPod, the screen says it has detected an iPod and asks if I wish to connect. I say yes then (here is the wierd part) the tv only picks up 7 songs...all of which have been deleted from my iPod months ago via the computer iTunes interface Library. I couldn't play the songs that appear on the tv on my iPod when it is not connected becuase they are not there. I believe I need some sort of "translator" between the iPod and the Samsung HDTV. Anyone know of one that would do the trick??
  • Anonymous Apr 10, 2009
    me to
SOURCE:
techman
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
SOURCE: i want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
nuwan chinth
  • 111 Answers
SOURCE: I have a samsung home
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Posted on Jan 08, 2009
  • 144 Answers
SOURCE: HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Posted on Jan 18, 2009
SOURCE: Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Posted on Jun 03, 2009
Hello my Samsung HT-x70 plays for about 20 minutes and then shuts off. Please help
First check in back that the fan is running. Second: Remove cover and check for bad capacitors in the back right corner. The ones in my system were blue. one had totally dissolved. I replaced the capacitor ad the system worked fine, Then found the fan was not running so replaced that too. It does take some soldering to repace the capacitor.
Jan 02, 2010 | Samsung HT-X70 Theater System
Samsung ht-x70 problem at loading dvd, it stay at a loading looping
I AM HAVING SAME PROBLEM WITH MY HT-X70 I HAD FOR ABOUT 3 YEARS NOW. I OPENED IT UP AND DUSTED THE LASER OFF BUT STILL NO LUCK. ONLY THIN I CAN THINK OF IS LASER IS BURNT OUT AND NEEDS TO BE REPLACED
Nov 02, 2009 | Samsung HT-X70 Theater System
My samsung ht-tx72
have you tried manuals.com?, not sure if they might have it, but they can find it for you
Oct 03, 2009 | Samsung HT-TX72 Theater System
Bought a samsung dvd home theater system HT-X70 off of ebay and its plays beaytifully for like 10 minutes into the movie and then all the sudden it flashes "PROTECTION" and then shuts off. I unplud it and...
Sounds like a heat problem, look on the back of the player and see if the fan is full of debris ( dust, pet hair, ect.) blow it out and see if that helps.
Aug 08, 2009 | Audio Players & Recorders
Jun 02, 2009 | Samsung HTP-1200 System
No sound from subwoffer
Check the fuse at the back of the sub it might have blown
May 18, 2009 | Samsung HT-TX72 Theater System
Samsung ht-z410 died. (home theater) no power
have you opened it up and checked the fuses
May 17, 2009 | Samsung HT-Z310T Theater System
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Blu-Ray disc stops playing after 20 minutes
New Blu Ray home theater player can not play new Blu Ray movies according to Samsung customer support. It is a JAVA code issue and they are working on a software upgrade. No release date is known. I tried playing The Hulk, Ironman and Wanted. None would play.
Thanks Samnsung for wasting my time and money!!!
Dec 07, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung Home theater system
i have the same problem, i've eventually resorted to putting a box fan next to it and taking the cover off....kinda ridiculous but beats buying another unit and this point
Oct 05, 2008 | Audio Players & Recorders
924 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
