Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Will not drain
My Whirlpool Ultimate Care II will not drain. What do you think the most probable cause may be? Should i attempt to repair it or call a technician?
email address:
  • MPWATSON Apr 19, 2008
    My Whirlpool Ultimate Care 2 will only fill; draining step will not occur. The drain hose is not kinked or plugged. I found this out by lowering the hose to the ground; all the water escaed without a problem. Is this a timer issue? Is this an expensive fix? Can I do this myself?
  • Franklin Ouchida
    Franklin Ouchida May 11, 2010
    How handy are you do you have some tools? drain pump is accessible you want to save money or time? Does it make noise when it should drain?
    let me know I can help you if you want to try it..
  • 1,073 Answers
Any more symtoms
Posted on Apr 13, 2008
I have a whirlpool ultimate care II washer. When I start the washer, water pours in but does not fill up the washer. The water immediately drains away. Its not leaking out of the washer. I think the...
This issue calls siphoning effect. It happens when the drain hose was somehow lower or not stand vertically. It causes no air pressure column in the drain hose to keep the water out. Check the drain hose and make sure it is high enough. Try to hold the drain hose straight up and see if it is happened before having further inspection.
Oct 05, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Have a Ultimate Care 2 LSB6300PW top load that will not spin. It fills, drains & agitates.
It's probably the internal springs that connect to the basket. You need a repairman. Make sure that black mold hasn't set in while you are waiting for it to be repaired.
Sep 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care II will not spin or drain
The primary promlem is draining. Make sure the drain hose is not kinked or blocked .Water flowing out when the hose is lowered ( the hose needs to be lower than the water level, inside the machine as well) would show if it's blocked. Another cause is a jammed or failed pump. Good luck....Nomess
Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate care II is leaking water.
Use the video to see how to disassemble the washer to check for the source of the leak.
The leak is probably in the drain pump.
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load won't drain.
Go to: by jsrock516. This is a procedure for replacing a motor coupling, but it describes removing the case very well. Hope this helps.
Dec 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
185 people viewed this question
Dan Webster
Dan Webster
Sal De
