I have a hp all-in-one printer 3050. i can recieved fax ok but i can't send a proper fax as they recieve my fax black and dark and can't read fax i sent. i think it might be my fax setting on fax machine.
    Sergeant:
  • 202 Answers
Hello cmcneill3
Does this happen w/ more than one recipient of your faxes?
If you haven't done so already, please, send a fax to a different recipient (one using a different machine to receive the fax on).
HERE is HPs information, downloads, etc. for your HP LaserJet All-In-One 3050.
I didn't find anything there that describes the issue your recipient is experiencing.
Please, use the All-In-One to make a copy of a document. How does the copy come out?
Please, post back w/ your answers and any other information you might have (the more details you can provide the better) and we'll see if we can get this issue resolved or at least diagnosed for you.
Thank you
BJ
Posted on Apr 05, 2008
Recieve faxes problem in hp laserjet 3050
- cables properly connected
- analog or digital (DSL, VoIP, etc) phone line
- dedicated line?
- under fax setup, all faxes, turn error correction off
- under fax setup, all faxes, turn v.34 off
- test fax
Jul 17, 2010 | HP LaserJet 3050 All-In-One Printer
My brother just gave me a HP LaserJet 3050 and for some reason i can't send or recieve faxes. What would be my problems?
First plug in the phone line into a working phone to see the the line works. If the line works you may need a new modem for the 3050.
Jan 07, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
When we send fax or copy it comes out black , can recieve faxes and print off fine .? hplaser jet 3050
Scanner's lamp damage
Try to open the lid on where we copy sheets of this paper hold down the sensor and press the copy button, see if the scanner lamp light, lamp power can be interrupted
Oct 27, 2009 | HP LaserJet 3050 All-In-One Printer
How do I set up my 3050 to get a report each time I send and receive a fax?
Press menu button printer control panel.
Select the option reports.
Selected all faxes reports and that should allow you printer the report everytine you send or recieve fax
Jun 30, 2009 | HP LaserJet 3050 All-In-One Printer
Cannot recieve a fax
i have a H P 3050 THREE IN ONE AND I CANNOT RECEIVE FAXES I HAVE COMCAST AND HAVE ALL MY SERVICES IN ONE, CABLE, PHONE AND INTERNET. DOES ANYONE KNOW HOW TO PLUG THIS IN CORRECTLY
Jan 13, 2009 | HP Office Equipment & Supplies
Fax procedure in laserjet 3050 model
Press the Menu button and there is option to set-up select that option and there is another option call fax set-up there will be three option.
Fax recieve set-up , Fax send set-up and all faxes set-up from these three options you can set-up fax on your printer.
Thanks and Regards
Nov 26, 2008 | HP LaserJet 3050 All-In-One Printer
MY HP LASERJET 3050 WON'T SEND FAXES
While its possible, I doubt your doing it wrong...
  • Select [FAX], place the paper as indicated on the tray, type the number, and hit send. That's about it.
However, Fax machines will not send when attached to a digital phone network, used over IP phones, or in conjunction with DSL service without the lines being conditioned. This is a small device which hides the higher frequency noise from the fax machine. Any sort of signal shared on the lines may interfere with sending, recieving, or both. If you use DSL for example, I'd almost guarentee this is part of your problem.
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Faxes sent through HP 3050 is unreadable
Following could be the reason behind this issue:
1. Check ink cartridges of the recieving printer.
2. Make a copy from your printer,if there is any problem while copying then replace the printer.
3. If the copying is not fine then clean the scan feeder, andif it is fine then it is an issue wih the other printer.
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
144 people viewed this question
jasbo
jasbo
