Sleep my computer does not stay on i plug it up and the red light flashes 10 times then goes off
    Sergeant:
  • 349 Answers
PC does not post:
· Remove any hardware you may have installed prior to you having the problem.
· remove the ram and clean the gold edges both sides, with rubbing alcohol or a pencil eraser, (not an ink eraser as it will do damage)
· and re-insert them,
· swap them around if you have more than one, try one at a time.
· if you only have one, borrow one from a friend or try the ram in your friends pc ,if that's possible,
· or take the ram to your local pc shop and ask them to check it for you (they may do that for you)
· if you can establish that the ram is ok, try a recovery /system disc's or bootable anti virus disc ,if that does not work, then it is most likely, that the motherboard or cpu has failed .
· Generally a dead hard drive would not stop the PC from posting.
good luck with that and let me know how you get on.
Terry
Posted on Apr 05, 2008
Power Switch comes on but moniter goes back to sleep.
use external monitor to setup internal monitor setings
Nov 10, 2012 | eMachines T3508 PC Desktop
Red light flashing constantly on dc16 when on charge, used to just stay permantly red without flashing until it went green when charged up.
I had a similar problem when I bought an after market 2Ah battery. Would stay solid red for a few seconds then flash red. I believe my problem was that the battery had gone into "sleep mode" I.e. it was discharged to the point that it "sleeps" in order to protect itself. So......I simply attached a domestic DC multi adapter to the terminals on the battery that are marked + and - (the 2 outside terminals on a DC16 Dyson battery). Switched on the DC adapter for around 10mins and this was enough to "wake" the battery. It now charges as normal attached to the DC16 in the Dyson charge mount.
For a pretty in depth article on lithium battery sleep have a look at this:
http://batteryuniversity.com/learn/article/low_voltage_cut_off
Oct 29, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Does the mouse & keyboard turn off or sleep?
check your windows settings. They are in your power settings. You can adjust your computer to whatever you want.
right click on destop and goto properties, then click on screen savers tab.. see the power settting button now?? You should be able to tell it what to do for everything to do with Power.
Apr 06, 2008 | Logitech Cordless Desktop EX110
Blinking lights
i have same problem, do anyone know how to fix it? thx
Jan 10, 2008 | Sharp LC-32P50E 32 in. LCD Television
Red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Nov 02, 2007 | Panasonic TH-42PX60U Television
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
