Question about Coffee Makers & Espresso Machines
Schaerer ambiente I need to replace my toolkit and screwdrivers for my schaerer ambiente espresso machine. Where can I order another set?
  • 4 Answers
If you are in usa, contact schaerer direct on:
Schaerer USA Corporation
2900 Orange Avenue, Suite 102
Signal Hill, CA 90755
Phone
888.989.3004 (within the U.S. and Canada)
562.989.3004 (outside the U.S. and Canada)
Fax
562.989.3075
E-mail
[email protected]
Service Dispatch
Select option 1
Technical Support
Select option 2
Parts
Select option 3
Accounting
Select option 4
Sales & Marketing
Select option 5
or Canada:
Quality Coffee Systems is at
1122 Boundary Road, Burnaby, B.C. V5K 4TK
E-Mail: [email protected] | Phone (604)291-6166
Posted on Apr 11, 2008
SOURCE:
Set grinding and extraction on ambiente
Grinder setting will not just affect extraction time, it will also affect taste. A fine grind will be slower but have a creamier look, a coarse grind will speed up delivery. From whatever setting you are on look at the result, you are after the good creamy top of a good expresso. only adjust one step at a time, and check a few cups before any more adjustment. You do not want it so slow that you have to wait ages, So go for coarsest grind with a creamy head. Overtime you might have to readjust due to wear, Select only one hopper at a time to adjust, Do not try and adjust when blending, one side at a time until both give same result and speed for same coffee, Then you can go onto blending.
Mar 05, 2013 | Schaerer Ambiente PS Espresso Machine w/...
Schaerer ambiente locked in the flash mode
If you have a Ambiente p/s espresso machine;
it may be stuck in cleaning
simply turn the machine off.. press and hold down the on / off & cleaning button release them at the same time look for the word " Clear Flag " if you see that word you should be out of the cleaning mode ... Note coffee boiler may not be up to temp.. or water flow is blocked..
Feb 21, 2011 | Schaerer Siena Espresso Machine
TRYING TO FIND A PART MANUL FOR A SCHAERER AMBIENTE ESPRESSO MACHINE MODEL-15SO S/N 0521428262 210 VAC 5200W 25AMP 50/60HZ
I can e-mail it to you. You need to check or contact "Fix Ya" and ask if is OK. for me to e-mail it.
May be you don't have to ask, I don't know the rules.
Jan 11, 2011 | Schaerer Siena Espresso Machine
Schaerer ambiente display saying" selection locked
the machine seriel number and or cust, number are missing you need a " service card or the machine " save data card "
Nov 29, 2010 | Schaerer Siena Espresso Machine
Just had our schaerer ambiente-1 espresso machine worked on by a certified shop (visions in seattle) yesterday and today it is still putting out water with the steam. please help! --of course visions is...
First You need to check the inlet water valve, I think the plunger is not working (sealing) properly and 2nd. Check the water level probe make sure is clean. If you don't feel comfortable doing this take it to a pro.
Nov 20, 2010 | Schaerer Siena Espresso Machine
Flowmeter error on an Ambiente Espresso Machine for Dunkin Donuts
Flowmeter A restriction of water flow.. is the drink interupted when you see this message if so replace flowmeter.. if not look for the blockage of flow coffee in the inlet tube to brew group,, calcified hot water boiler inlet tube plugged pistons..
Sep 27, 2010 | Schaerer Siena Espresso Machine
I have a schaerer opal coffee machine, when I switch the machine on, the water light flashes, and a pump runs continuosly as if it is trying to purge the machine. but nothing comes through. does anyone...
I have a schaerer opal coffee machine, when I switch main power machine on, the descaling indicator, cleaning/rinse indicator and stand-by mode indicator lamp remains lit, and a pump runs continuosly. the machine do not ready mode indicator. Yudi INDONESIA
Apr 05, 2009 | Schaerer Opal Espresso Machine
Coffee Makers & Espresso Machines Logo
395 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
