Question about Canon PIXMA iP1800 InkJet Photo Printer
Can't put cartridge into printer.. .
Hi oldnovii,
Sorry didn't reply so soon because I was away doing research. Your instruction is so clear but I have a bit of a problem. Which side of the cartridge is going to fit into first? I think if you can send me a photo will really works better. I don't really know which side of the cartridge to fit in first. I went to the website you have given me for routine maintenance to look for manual but I can't find any.
Looking forward for your help. I'm waiting oldnovii.
Thank you, Luviz
  • tia1020 Apr 16, 2008
    how to install the ink cartridges in the printer ip1800
  • Luviz Apr 19, 2008
    Hi old marine,
    Oldnovii had fix the problem already and the printer cartridge is printing very well.
    You know why can't put the cartridge into printer? Because the lever where to fit in the cartridges was stucked at the right side of the printer even though the printer was on. I thought there's nothing for the cartridges to sit on, until I was able to touch and pulled it slightly. Suddenly it shifted or moved to the left.
    Well, any way it is fixed now. In the future it might happened to someone. . .
    Thank you very much for your support.
    Kind regards
    luviz
  • 2,016 Answers
Go here. Type "how to install ink" in the search field. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures of how to do it.
Posted on Apr 17, 2008
I have just installed new HP cartridge but error message - cartridge alignment failed - keeps appearing despite printout looking OK?
It is a multi-function printer> What model? if, all-in-one model, did you put the cartridge alignment printout on scanner and press Resume?
Jul 20, 2011 | HP Office Equipment & Supplies
Printer stops working. Error 5200
Hi there. i understand that you're having problems with your canon printer.
regarding with the error code..here's what you can do about it:
  1. On the operator panel, press the <ON> button and the display will go blank..
    Ooopz! Take Note: On rare occasions, it may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
  2. Wait approximately five to ten minutes and then press the <ON> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
and if it didn't work, try to replace the ink cartridges of your printer,,
if you have any more questions..
dont hesitate to reply on this message..
Good Luck!
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
Printer will not work it gives me error:oxc18a0306
Hi lee1071. regarding with your photosmart printer.. there's 2possible reason why the error message pops up..
1st: if the ink cartridge is bad and if the cartridge is a refilled ink cartridge 2nd: there's problem with the print mechanism of the printer.
most of the time, that error code can lead into a hardware failure.
now, here's what you can do..
if you will notice there's a carriage that is holding the ink cartridges of your printer..that is removable, there's a latch on the right side of it..pull it up and remove the carriage..after that..soak the carriage on a lukewarm or it'll be better if the water is a boiled water for you to melted the inks that clogged on the electrical contact and leave it for about 10mins..after doing that, remove the carriage and dry it using a tissue or dry cloth..
put the carriage back in but make sure that it is fully dry, lower the latch and put the ink cartridges back in. after that turn the printer off and on..
and if it didn't worked, then theres really problem with the printer itself.,
if you have any further question.. dont hesitate to reply..
thanks.
May 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
I ran out of black ink and I really needed to print something so I had some ink and refilled the cartridge and it is showing me error code 3507. Do I have to buy a new cartridge even though this one has...
As per KODAK's recommendations,
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact KODAK.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
  3. If the error continues, contact KODAK.
These steps are part of KODAK's Error: "Black ink cartridge needs replacing" (3507) page.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 14, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Printer unable to clean
Your "excess toner cartridge/pad" is probably full. The reason it didn't clear when you turned it off is because your printer has a "counter" that didn't get reset during the power cycle. You can manually reset this "counter", which will clear the error and allow you to print. You have to bring the printer into Service Mode and find a counter and reset it, when you reset the correct one, it will clear the error.(sorry I cannot give you definitive instructions on how to do this)
But eventually your "excess toner cartridge/pad" will NEED replacing becasue toner will spill out of it and into the printer. Pretty simple, it's like a big sponge.
Reset the counter and you will print. But replace the excess toner pad soon.
Sep 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Replaced cartridges
Hi there :
on mine i had to use some rubbing alcohol and clean the new cartridge and the contact area on the p[rinter then reinstalled the cartridges and kept running the cleaner program and then about 15 sheets of paper later it finally cleared up and the color returned to normal and i had no more prohblems
Mar 07, 2009 | Canon PIXMA iP2000 InkJet Printer
I can't remember how to change the ink.
Hi pamkrueger, sorry this is rather late reply, but your query seems to have got lost. Your handbook (on you printer CD) provides clear instructions on how to change the ink cartridges. If you've lost the CD, you can download the manual (or read it on-line) from the Epson Website - just click on the link below.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=dkmEK02SU002Fer6qudElZT5RAigWmhd68AXFaiPGMjSX+IU003D&tc=5
Dec 23, 2008 | Epson Stylus C46 InkJet Printer
Mistake made
Dear Debbie.  The way I believe it works is that a lot of people try to answer  your questions for free; Failing that after a period of time 'I believe they offer to sell you the answer from others whom will take a lot more time researching and finding the answer for you for a fee.
Dec 14, 2008 | Lexmark X1270 All-In-One InkJet Printer
Error message "no cartridge" won't go away on my brother mfc 420cn printer
Sorry i couldn't help on the day you nedded it. Do not be afraid to refill, it's easy once you have a go, all instructions come with the refill kits, and they instuct on your specific printer too. Follow it to the T and you can refil one colour or all, and no waste. Once refilled, replace it, reset ink levels, and try printing again. Good luck.
Aug 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
