My disk started to freeze so i turned the power off on my drc260 and after a short time turned it back on, now all it will do is say loading and only way to get it to stop is to unplug the player, no blue screen or anything else, just loading
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Sounds shot to me but you can try...
you can go to wal-mart or any electronic store and get a laser eye cleaner for DVD - I recommend the Philips system, for under $15 you get the DVD laser eye cleaner and a disk cleaner with a micro fiber cloth it's a great deal just DO NOT use it in a laptop, laptop's take a different type but the disk cleaner is universal
Posted on Apr 05, 2008
PS3 keeps freezing with colorful pixels. How can I fix this?
You need to use a vacuum and suck the back out or blow it out with air . While power is off on PS3 turn power on holding down the eject button it will blow it self out .
Sep 20, 2014 | Sony Playstation 3 (PS3) Console
I am not sure on how to wire the freeze protection wires to the time clock. i know they must go to the load side of the clock for the main pump but will this reverse the power back into controls and short...
Here's a 240V diagram with clock timer and freeze control:
Add a comment if explanation does not fit your exact timer:
See image full size:
Here's how freeze control works:
Freeze control is like regular timer, except it turns ON by thermostat instead of time-clock
Freeze control turns ON pump whenever thermostat kicks on.
Both clock-timer and freeze-control are wired to pump in 'parallel' so to speak.
Think of it as having two controls wired to same pump...
Both controls can turn pump ON-OFF.
If one turns ON, and other is OFF ... then pump is ON.
If both are ON, then pump is ON ... and electricity just flows around on extra wires.
If both are OFF, then pump is OFF.
Say it's below freezing all day.
Freeze control circuit is ON all day ... pump is ON all day
Clock timer turns ON > but circuit is already ON, so timer just opens more wires for electricity to flow around on.
When clock timer turns OFF > freeze circuit is still ON because it's below freezing ... pump is still ON.
240V wiring:
Power leads coming from circuit breaker go to terminals 1&3 on clock-timer
Same power leads connect to freeze-control-black and freeze-control-red.
Or connect freeze-control-black and freeze-control-red to terminals 1&3
This action puts power to clock and power to thermostat
Pump wires connect to terminals 2&4
Same pump wires also connect to freeze-control-blue and freeze-control-yellow.
Or connect freeze-control-blue and freeze-control-yellow to terminals 2&4
This action connects pump to both freeze-control and timer.
When either clock-timer or freeze-control turn ON, then pump turns ON.
Nov 15, 2010 | Intermatic Timer PF1222TB Multi Circuit...
My iMac g4 1ghz wont boot
First hold down the right hand shift key down when you start, this does some housekeeping, The next step is if you have an install disk or tiger disk then start up from it by holding the "C" key down when starting and inserting the dvd, if this loads then go through the install menu, dont worry you do not need to actualy install just select language and then you get to a screen where you can select utilities from the menu bar, then select disk utility and repair permissions, after that do a repair disk then quit disk utility and change the startup disk back to the hard drive and restart, if for some reason you cannot repair the disk, this refers to the catalogs it uses to keep track , not the data itaelf, in that case you need a 3rd party utility like Disk warrior.
Feb 24, 2010 | Apple iMac G4 Desktop
My PS3 doesn't read disks that i insert!
It needs a new laser because the old one is "burnt out". It's a really common problem with them.
You could replace the laser or the entire Bluray drive.
I buy my parts at - the laser are about $75 each and Bluray drives are about $95.
In your caseme, best bet might be to get the whole drive.
I run a repair business and that place has best prices aside from Hong Kong which I don't trust.
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
Power present, will not load...
  • If your system boots properly and freezes when the window appears then the "sys" file of the operating system is deleted or got corrupt.
  • if the system freezes before you could see the window screen then your OS is not loading properly.Which could be due to following
  1. check the hard disk type in the BIOS and look for SATA and ATA type. Correct if it is changed.
  2. OS got corrupt.
  3. RAM not functioning.
  4. check the boot order in bios too.
  5. hard disk gone.
hope through this you will be able to figure out your problem.
Thank you
Aug 16, 2009 | Sony VAIO VGN-NR120E/S Notebook
Ps3 says cannot start the correct hard disk was not found
try safemode
hold down the power button while the console is in standby. the light will go from red to will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Tecra 8100 Freezes shortly after Windows comes up
Go into your hard disk utility and defragment your file. When the computer writes to your hard disk over time these files no longer are sequential as they were in the beginning. This is one solution, also you can do a disk recovery using your original disk or by pressing F10 as it boots up. Be sure and do a good check for viruses as well. The symptom you are describing sounds alot like a virus that is slowing your system down more and more. Good luck.
Jan 14, 2009 | Toshiba Tecra 8100 Notebook
Freezing and then making a buzzing sound
You should make sure your disks are not scratched. You are able to turn the wii off without removing the the lead thing. Just hold the power button for a while on the counsle until it shuts off. Just out of curiousity.......and maybe a thing.........because this happened to froze because i entered a cheat and skipped to much in the game, but when i went back and did it the real way, it didn't freeze.
Nov 19, 2008 | Nintendo Wii Console
System Lockup
Best bet is to contact Ninendo Tech Support at 1-800-255-3700. Hope you figure it out!
Aug 28, 2008 | Nintendo Wii Console
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
