Question about Epson Stylus RX500 All-In-One InkJet Printer
Epson stylus photo RX500
Changed the blank cartridge a week ago. printer worked fine.
copied a form yesterday and one page printed fine, the second was barely visiable. It was not jumbled, just not printed.
Cleaned the nozzles twice, printed a nozzle chech and got only the yellow color.
I have read some place that a cartridge cannot be removed and reinstall in these epsons. In the process of checking things out, I may have removed some cartridges and reinstalled them, I certainly did the black for sure.
I have no error message, and ink levels are 60% for all colors and 80% for black.
Any help is appreciated.
HK
    Problem Solver:
  • 17 Answers
Turn the printer off overnight and try the head cleaning process again. Leaving it unpowered for an extended period softens the ink and makes the cleaning more effective. It may require several cleaning cycles.
Posted on Nov 14, 2008
SOURCE:
MOVING THE CARTRIDGES TO MIDDLE OF PRINTER TO ENABLE ME TO REMOVE THEM AND REPLACE - CAN'T REMEMBER HOW TO DO IT
The steps are on pages 111-114 of the RX500 user manual:
http://files.support.epson.com/pdf/rx500_/rx500_u1.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | Epson Stylus Photo RX500 Printer
My Epson Stylus PHOTO RX500 will not print!
you may need to reset the printer that may help it if you dont have the software then call me back i and i will give it to you
Nov 29, 2008 | Epson Stylus Photo RX500 Printer
Goes though the motions but does not put ink on page
The problem might be a faulty print head. Try to print out a nozzle check and do a couple of head cleanings. I would like to know more info about it. Does it happen when you print from you computer? How about when standalone copying?
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson RX-500 ink's full but won't print
u just have to replace the refilled cartridges.and insert new orignal cartridges.this is a very common problem in epson printers that refilled cartridges work sometimes and sometimes dont.so insert new orignal cartridges to have good printouts.
Sep 09, 2008 | Epson Stylus RX580 InkJet Photo Printer
Epson stylus rx500 prints too magenta-ie
Try replacing the magenta cartridge...
Does it also do this when you try to use it as a copier? If so,
try to clean the head.. If it only happens when you're printing from the computer, try to reinstall the driver
Jun 30, 2008 | Epson Stylus Photo RX500 Printer
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
Feb 09, 2008 | Epson Stylus RX500 All-In-One InkJet...
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Printing black and white
try a few head cleans or it could be cheap catridges dont refill them, and dont buy the cheap nasty catridges
Jun 28, 2006 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus RX500 All-In-One InkJet Printer Logo
170 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
