FixYa.com
Tags:
Brother SE-270D Computerized Sewing Machine
The safety device has been activated. (by 4 users)
posted by sew-phie on Apr 05, 2008
Okay, fair enough. The needle does not appear to be bent. Neither the upper or lower threads are jammed. And not the machine will not sew. Horrible grinding noise and the balance wheel is locked and won't budge an inch. I bought this machine for my Mother's birthday in October. This is only the 3rd time we've used it!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on May 16, 2008
safety device activated terrible knocking sound
Comment by Guest, posted on May 13, 2008
horrible grinding noise safety light conmes on material gets pulled into needle opening i changed the needle . rethreaded upper and bobboin threads cleaned out bobbin casing changed bobbin i only had it 2 weeks
Comment by bribear, posted on Apr 13, 2008
I am using this machine for the first time and trying to wind the bobbin. each time I press start it tells me the safety device has been activated.Nothing is jammed because it has never been used. Please help
Solution #1
Not Rated (0)
deboliver
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
my SE 270D makes a loud knocking noise and the needle is bending and breaking the safety device came on and the bobbin spring that holds the bobbin in place will move you can pick it up and the bobbin will not stay still when you move the wheel can anyone tell me if that piece would be broke and is it expensive
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 11, 2008
Not Rated (0)
bargainbox
Rank:Guru Guru
Rating: 86%, 131 votes
It is under warantee for 12 months, so I would recommend you phone the dealer to arrange for them to have a look at it.....if you have any samples of sewing, take them too.
Can you Help with these Sewing Machines problems?
it will not sew safety device...
it will not sew safety device... Answer This...
part fell off
automatic threader foot fell... Answer This...
thread gathers under material
While embroidering, the thread... Answer This...
Thread Cutter Button
My thread cutter will not cut... Answer This...
Brother Disney SE-2700 carriage...
The computer screen on the... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
