Question about Gateway M675 Notebook
I HAVE M675 GATEWAY
THE SCREEN WHEN BLACK BUT IF I SHINE A LIGHT ON IT I CAN SEE THE INFO
  • ACETVW Apr 05, 2008
    THANKS JUST ORDER AN INVERTER
  • 3 Answers
I had the same problem. It turned out to be my inverter which is the cheaper and easiest part to repair. The CCF lamp is sodered on and hard to access. HTH's
Posted on Dec 01, 2008
    Brigadier General:
  • 6,966 Answers
This could either be a defective CCF Lamp or the inverter that powers the lamp. In some instances, it could also be a simple case of cold solder/loose connection in the inverter circuitry or the connector to the lamp.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 05, 2008
After using my Gateway M 675 prr and now it is not working. The screen is black, the fans are working and the lights are on, just have a black. What can I di?
The Gateway 675 are known for video card problems.You can unseat the card and clean it,then replace the thermal grease.The thermal grease on these get runny under heat and causes the video card to loose contact.Try the grease if that doesn't work the video card will need to be replaced.
Jun 25, 2011 | Gateway M675 Laptop
Describe your Gateway M675 Laptop w/ Pentium4 Gateway M675 won't maintain a charge after charging and the display flicks from ac/dc until the battery is completely empty. Do I need a new battery or power...
Sounds like you need a new power adapter.The M675 needs the correct voltage constantly to work correctly.I'm using one right now and it does the same thing with the wrong adapter or a weak adapter(low voltage).M675 is a great laptop but with the 3.0ghz its got to get the power it needs especially when its under a heavy load.
Oct 26, 2010 | Gateway M675 Laptop
I have a Gateway M675 laptop. It starts up just fine until you add a second stick of menory in the second slot. It will start with one stick in either slot but when you fill both slots at comes on, the fan...
Its possible that your slot could be dirty, you can try re seating the stick and then cleaning it with a brush. If that don't work you can just run it with one stick, last resort is to replace the motherboard.
Feb 24, 2010 | Gateway M675 Notebook
Screen does not com on gateway m675
use a flash light shine on screen if you can see the desktop real faint your invrter for screen needs replaced also you can hook up external monitor see if screen comes on on it if not then sounds like video card is shot
Dec 10, 2009 | Computers & Internet
My Gateway M675 laptop doesn't allow me to display video on an NEC np61 projector...I connected the cables before turning the PC back on and I see the Windows screen, but not the video...
Here is a direct link to the user's manual of the M675:
http://support.gateway.com/s/Manuals/Mobile/9528976.pdf
On page 65 of this manual, there is a detailed description of how to get this laptop to work with projectors.
Nov 06, 2009 | Gateway M675 LAPTOP LCD HINGE/CLUTCH (L+R)...
I have a Gateway M675. I am installing a new hard drive. When I powerup, it displays a black screen and you can hear the fan running... or it will show the Gateway logo, then type in a paragraph the ends...
Dear,
1 Please install the operating systems in this hardisk 2. Set BIOS to boot from the New System 3. still it fails, there is an issue with boot sector of your hardisk.
Oct 18, 2009 | Gateway M675 Notebook
I dropped my laptop
any lights on the front display? (Also check the light on power adapter)
Dec 26, 2008 | Gateway M675 Notebook
Gateway laptop m675
Seem to be an inverter problem.
Sep 24, 2008 | Computers & Internet
Gateway M675 creen problem
Yes you are correct and they are beggars to fix.  Your problem is fixable just ask these chappies:
http://lcdrepair.net
Oct 10, 2007 | Gateway M675 Laptop
Gateway M675 Notebook Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
