Question about Apple iPod nano
My iPod won't go to sleep
  • my iPod wont go to sleep
  • i hole down the pause button but it doesnt work
  • i go to the main menu and press sleep and it doesnt go to sleep
  • unless i put it in a charger it sits around all day on "on" and looses charge
  • Anonymous Apr 09, 2008
    my nana just freeze it will not turn off
    ron
    Problem Solver:
  • 15 Answers
Try holding down pause and then move the hold switch sraight after. hope i was a help xx
Posted on Apr 08, 2008
SOURCE:
30gb ipod freeze up cant shutdown to reboot
Slide the Hold button on the top of the iPod so no red mark is visible. Press the main menu button until you see a long list of options (Artists Albums Songs Extras......) use the scroll wheel to find the sleep press and hold the center button in or Locate the Play/Pause button on the iPod. The Play/Pause button is at the bottom of the wheel around the select button. Press and hold the Play/Pause button until the unit powers off, about three to five seconds. Press any button on the iPod to turn the power on.
Feb 14, 2013 | Apple iPod Audio Players & Recorders
Trying to swicth off my i pod
Feb 03, 2013 | Apple iPod MA446LL/A MP3 Player
My apple ipod touch wont turn on
I've seen this before. You need to reset it.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
I hope this works!
May 10, 2011 | Vacuums
Have 4th gen ipod nano, charged it up but dont
theres no switch of on ipod, only sleep, just dont forget to sleep and lock it if your not gonna use it.:)
Sep 30, 2009 | Apple iPod nano 3rd Generation
IPod 4G does not resume properly (loses its place) after sleeping
Hi, What you can do is :
1) Try connecting your IPod to computer and open itunes
2) Update the software.
3) Try pressing down "Menu and Center Round button together untill you see a Apple Logo on the screen"
4) Then you can try using it and issue should be resolved.
Feb 03, 2009 | Apple iPod nano
Buttons arn't working
Hi!
Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step until apple logo appears.
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
To reset your iPod
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
iPod not responding If your iPod does not respond to these steps, see additional steps in the "iPod troubleshooting basics and service FAQ".
Additional Information Apple releases new versions of the iPod Software Update application from time to time. These later versions may include new functions or improvements to existing features. Learn about updating iPod's software.
To return iPod to its original factory settings, use the iPod Software Updater utility to restore iPod.
Jan 30, 2009 | Apple iTunes
Ipod nano 4th generation 8gb purple wont turn off
no there is nothing wrong. This is normal, after you turn it off by pressing the hold/pause button switch it into the locked position. When you take the lock off and press anything it will come back on exactly where you left it. Don't worry it is not faulty. it is supposed to do this.
I hope this helps
Jan 10, 2009 | Apple iPod nano MP3 Player
Ipod nano 4 gb is frozen
Press and hold the center button and the menu button at the same time. This will reboot your Ipod.
Dec 22, 2008 | Apple iPod nano
30 gb ipod wont shutdown
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
