Question about Samsung HLR5667W 56" Rear Projection HDTV
Blown picture and BUZZING?!?
Watching TV, then a very loud noise.  It sounded like glass falling or a bulb breaking.  Obviously might be my lamp right.  But . . . what makes this really complicated (because I can't find anything on the net about it) there was an regularly repeating buzzing noise.  It was almost like a fire alarm.  It repeated every five to 10 seconds or so.
I think I have a blown lamp, but why is it buzzing?  Any suggestions on what else this problem may be?
Thank you very much for the help.
  • hyginx1 May 22, 2008
    Sanyo HL-P5063W had same problem. Explosion sound inside and click on and off, but no more picture. What do I need to do to fix this??? THX!
Most likely yo problem is the colour wheel it's been failing in a lot of dlp tv's i called samsung and that's what they told me.
Posted on Jun 11, 2008
  • Samsung Master
  • 8,617 Answers
Could have been the ballast shorting out which could have destroyed the lamp.
Posted on Apr 05, 2008
SOURCE:
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
Bulb has gone out and now makes a loud noise
The noise depending on where it came from may be normal. You wont be sure unless a TV repairman checks the boards to know for sure, or you could replace the bulb and hope for the best.
Jul 19, 2010 | Panasonic PT-56DLX75 56" HDTV
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Set was on and made a loud pop noise and the picture went off. the red light was flashing and no picture. then it made a strange buzzing type of sound a few times. turned off for a couple mins and then...
It sounds like your screen inverter has just gone >bang< unfortunately.
Most screens inside use 2 main circuit boards, and you are most likely going to have to change one of them.
It's possible also for it to have been just the backlight bulb making the loud pop noise too. The inverter may have given out too much power and blown the bulb (a lot like you hear when a house bulb goes bang).
If you can't actually hear any TV sounds (normal sounds like music, voices etc. when they should be there), then it means the problem is more serious, and would need a specialist repair place to check out the electrical circuit inside.
Mar 30, 2010 | Sony KDF-E42A10 42 in. LCD Television
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Loud whinning noise then no picture or sound
Color wheel is the noise you are hearing. It can also keep the lamp from firing up if it has seized up. Remove the lamp and inspect it. Replace the color wheel for sure.
Jan 10, 2009 | Samsung HL-R5678W 56" Television
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
[email protected]
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Samsung HLR5667W 56" Rear Projection HDTV Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
