Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis 27092---won't respond after error message cleared
Washer came up with an "Ld" message, indicating a possible slow drain problem(had about a year, and first time message has appeared). Checked drain hose and pipe. Both appear fine, with no sign of clogging. Machine then displayed "Sd", indicating possibility of too many suds, but used "he" detergent like always. Then I tripped house breaker for washer for well over a minute. Message cleared. I started normal procedure to either "rinse/drain" or "normal" wash cycle(tried a couple of times for each). Washer acts like its working fine when I first try and start a cycle, but then when I press "start" it clicks as usual, but instead of starting cycle, it does nothing. It then will beep really fast three times or so when I press any button. Washer stopped initially with full tank of water. Got warranty, but Sears can't be out for a few days. Thanks for any help on a solution, and/or explanation.
    Novelist:
  • 184 Answers
THERE HAVE BEEN ISSUES WITH THE CONNECTORS ON THE MOTOR CONTROLLER AND MAIN P.C. CONTROL.
IF YOU CAN GAIN ACCESS TO THE CONSOLE, WITH THE UNIT UNPLUGGED, TRY DISCONNECTING EACH CONNECTOR FROM THE BOARDS, ONE AT A TIME, AND PLUG THEM BACK IN. THIS WILL CLEAN THE CONTACTS ON THE BOARDS AND MAY REMEDY THE PROBLEM.
DISCONNECT ONE PLUG, THEN RECONNECT IT. THEN, MOVE TO THE NEXT.DO THIS UNTIL EACH PLUG HAS BEEN REMOVED AND RECONNECTED. THEN PLUG IN THE WASHER AND SEE IF THERE IS ANY CHANGE.
Posted on Apr 05, 2008
SOURCE:
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Have Kenmore elite oasis that is coming with Ld code then F32 which means machine is taking too long to drain. The pump runs fine pumps all the water out. The hose is not clogged water drains freely....
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
LD = LONG DRAIN
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 02, 2010 | Kenmore Oasis HE 27062 Top Load Washer
I'm getting the LD message indicating that I'm having a drainage issue. I've taken the back off, inspected the hose and found nothing. The pump looks clear. I don't want to put it all back together...
make sure there is nothing in the hose the comes down from the tub to the drain pump.
there could also be something small in the drain pump that is slowing or stopping the impellar
make sure the connections are all in good order
Mar 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Ld error
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
Good Luck!!
Thanks
Jun 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE top loader has LD error code
Jun 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Ld code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question !!!!
Jun 02, 2009 | Kenmore Oasis 27042 Top Load Washer
Ld code on any cycle
Feb 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
107 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
