Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
When I attempt to fax something, a printout comes out that says it failed due to poor line condition. This never happened before and all the phone lines in my home work fine.
  • 1 more comment
  • shadow59630 Apr 05, 2008
    There is no static on any of the lines in my home and line has been plugged into the correct port every time. The troubleshooting section of the manual recommended I change the resolution to fine or s. fine. Neither of those settings has solved my problem. Thanks for helping anyways.
    The reason I say there is no static is because I've experienced that problem recently and it was completely resolved by the company. I checked this morning where I sent the fax and it came through. So I concluded that I can send and receive faxes but how do I deal with the annoyance of a printout (that says I have poor line connection) that comes out everytime I send a fax?
  • shadow59630 Apr 07, 2008
    Hey you were right about the tx being on. However even after I turned it off the report still printed. I printed a user settings report and it verified that the transmission report was off as well as any other reports. This is becoming very annoying and ink consuming....
When I press start to send a fax, it shows receive and do not go through.
Posted on May 08, 2008
  • 82 Answers
Can you recieve faxes okay or isit just when you send ? you should know that your fax machine will not work properly if you get any staic in your phone line, you may want to check by listening to that particular line or you may have it plugged in the wrong socket. the correct one is the one labeled " L " or line and not telephone.
Thank You,
Mikey
Posted on Apr 05, 2008
  • Anonymous Apr 05, 2008
    Are you having a problem when sending or recieving or both ?
    if both then i would call your phone company and tell them you are having trouble with your fax line, the human ear can not ussually detect static or some problems with the phone line, but the phone company at no charge can tell you if there is a problem with the line and whether it's internal or external.
    Thank You,
    Mikey
  • Anonymous Apr 06, 2008
    you must go into your reports program menu nad select the tx error report to be turned off. that should fix it.
    Thank You,
    Mikey
SOURCE:
POOR LINE CONDITION
Do you have DSL internet coming into the location where you are attempting to use the FAX machine? The reason I ask is because, if that is true, you may have a filter to reduce noise and that may be causing problems. I have DSL and whenever I use my FAX machine I have to unplug the filter from the phone wall receptacle and plug the fax line straight into the wall phone receptacle. Here is a photo of what
you may find if you have DSL.
Jan 25, 2014 | Brother Office Equipment & Supplies
Error 322 How to fix it?
There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Oct 15, 2013 | HP Officejet 7210 All-In-One InkJet...
My 575 fax won't send; it keeps printing "poor line condition". Is there something I can do? I am just trying to send a fax like I always do. It makes the noise at first like it does when it transmits,...
If this is happening to only one number you're trying to fax to, then the problem is most likely on their end, not yours. If it is happening with all the numbers you fax to, then I would suggest checking the telephone line hooked to the fax. Look for loose connections, or perhaps a bad cord from the phone outlet. The connection could be good enough to get a dial tone, but not secure enough for the fax to operate. If none of that holds true, I would suggest taking it to the shop and let a technician look it over.
Oct 23, 2010 | Brother FAX-575 Plain Paper Thermal
Sometimes my transmission reports say poor line condition att says my line is ok any ideas?
Unless you are paying for a "facsimile" line...the odds are that you are paying for a phone line and using a fax on it. The responsibility of ATT is to provide you with a line which meets phone quality. If you are getting errors due to occassional poor line connections these may not even be due to poor lines in your local area. See about getting your fax set to allow more "error" pecentage to be received before giving errors...probably need a service man for that adjustment tho".
Oct 11, 2010 | Brother Office Equipment & Supplies
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Error code 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted.
Number of possible causes, check the phone line, try a different fax number for a start. Is there other fax machines in the office on the same line
Sep 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
I have trouble faxing over my voip line
SOUNDS AS IF YOUR PHONE LINE IS THE PROBLEM. LAWRENCE
Sep 25, 2007 | Brother FAX-8360P Plain Paper Laser
"poor line condition'
This is a problem with your voice over ip service. You have to change the setting on your fax machine for example the Baud speed down to 9600, the ECM= off, and the Oversea settings on. Make sure your VoiP ATA is the first thing after your modem or whatever connection you are using for the internet. If you using and old model fax 95% of the time it will not work with VoIP service.
Jun 12, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
176 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
