Question about Creative Labs ZEN SLEEK MP3 Player
Wont work Today I pulled out my Zen Sleek to listen to my music, and it wouldnt turn on....i connected it to my PC thinking the battery may have been dead, and after a bit it started the reboot.....and froze about halfway through the process......i tried reseting it, but nothing will work....please help if you can thx
  • 4 more comments
  • Anonymous Jul 12, 2008
    ihave the same problem, like mine will freeze when the creative logo is on the screen, what do i do?
  • juliaggonzal Jul 15, 2008
    same problem, light for power is on but screen is black. charging for over 8 hrs, connect to my comupter and it will not light up the screen.
  • khn9244 Jul 19, 2008
    My Zen sleek photo does not work with neither batteries or power or connected to the computer. Please help.
    kim
  • Paddedmind Jul 27, 2008
    won't power up. I have tried charging it with my computer and the wall outlet and neither will bring it up. when I push the power button the light under the power button will flash off and on as hold the button down but that is it.
  • Anonymous Mar 13, 2009
    light goes on but screen stays black, does not start up
  • Anonymous Apr 09, 2009
    My Zen Sleek wont turn on unless I plug it into the charger. After it turns on it just says Zen Sleek and remains frozen.
  • 8,596 Answers
Get recovery tool from Creative website
Posted on Jul 06, 2008
SOURCE:
Won't Import MP3's From Computer
Try this...Push a pin into the reset hole at the bottom of the player while at the same time holding down the play and power buttons. Next on the recovery screen that shows up, run the ":clean-ip" function. Then try again to import the music files.
Aug 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
Zen sleek Mp3 (20 gb) SCREEN PROBLEM!! HELP
There is no repair service for a cracked screen - the whole player has to be replaced -sorry
Jul 04, 2008 | Creative Labs ZEN SLEEK MP3 Player
Getting out of recovery mode
The recovery tool mentioned above is not designed for the sleek photo. You need to download the firmware for the sleek photo from creative's site. Now we need to get your player recognized to get the firmware loaded. If you have Windows Media Player 11, it needs to be removed. Also remove WMP runtime. After that, restart the pc and your player should be recognized. You can then double click on the firmware program to run it. It might say something like, this firmaware is already installed...do you want to reload it? Click yes to reload.
I had the same problem with my sleek photo. Once I got rid of WMP and the runtime everything worked like a charm.
Jul 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
Computer stopped recognizing USB cord from Zen sleek photo
The first problem is probably a software incompatibility between Creative's software and Windows Media Player version 11. The second problem is possibly a need to replace the battery. 3rd party batteries are about 20 dollars now.
May 28, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Why zen sleek photo won't download music
i have a zen sleek and every time i turn it on it says rebuilding library. It completes this but deletes the last album etc that i put onto it. back down to the last album i put on before it started doign it. So i cant put anymore mousic on becuase it deletes it..Any Help?
Apr 17, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Zen sleek frozen / recovery mode
try this
http://www.anythingbutipod.com/forum/showthread.php?t=10960
If that doesn't fix it try the USB cable
Jan 15, 2008 | Creative Labs ZEN SLEEK MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
My mp3 player is dead
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Aug 06, 2007 | Creative Labs ZEN SLEEK MP3 Player
Zen sleek frozen after trying to delete songs
Why does technology make you work for what you already paid good money for? Have you tried going into Recovery Mode? You do this by holding down the Play/Pause button while triggering the Reset button. Once there, you have four options. Try selecting Disk Cleanup and then Reboot. You might need to re-Sync a few things but it's worth a shot. Good luck.
Dec 16, 2006 | Creative Labs ZEN SLEEK MP3 Player
Synching from computer not working!
update the firmware from creatives website.
Oct 29, 2006 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
207 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
