Parts need to find the red and blue cathode ray tube for a RCA Television model # D520W20 Chassie # ITC222
  • 8,617 Answers
I have some sources for used tubes. New ones will be really expensive if you can find them. I will repost tomorrow and let you know if I was able to locate any.
Posted on Apr 05, 2008
SOURCE:
I have Zenith rear projection TV Model IQC60H95W.The blue tube does not work. The red and green project. Is this a bulb or tube and are they available to purchase? The TV was made in 2001
This is a CRT(cathode ray tube) not a bulb. A Bulb is totally different. If you replace one Tube, you need to replace all 3 or the colors will never match properly. However, This model no longer has parts available. Even if they were, the cost would be close to $1000 in parts. I would not recommend repairing this TV.
Sep 14, 2014 | Zenith Televison & Video
My t.v.focus is like double vision and the color is not right.
convergence failure that tv has 3 CRTs-cathode ray tube- and it has a circuit that keeps each picture projected from the tubes aligned together called convergence. so if you have a picture that has 3 pictures of the same image in red green and blue then it is defintely a convergence failure. the part numbers of the parts causing the failure are STK394-160 and there also can be some burnt resistors in the same circuit.
Jan 06, 2011 | Hitachi 57F500 57" Rear Projection...
The red green and blue light are not aligned
Install the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Aug 07, 2010 | RCA R52WH73 Projection Television
AUTO CONVERGENCE DOES NOT SHOW IN SETUP RED BLUE
the repair kit is available from www.tvrepairworld.com its called the ITC222 and ITC222 convergence option missing repair kit. The kit contains the parts and the CD with instructions.
May 10, 2010 | RCA R52WM24 52" HDTV Projection Television
I have a RCA HD52w59 model an it needs conversion adjustment the picture has red,blue,anyellow around it tryed using menu button but no luck
the repair kit called the ITC222 and ITC222A convergence misssing repair kit should solve hat issue. The kit also contains instructions and is available from www.tvrepairworld.com
Apr 28, 2010 | RCA R52WM24 52" HDTV Projection Television
Too much red in the screen
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | RCA P52812BL 52" Rear Projection...
Doulbe picture with red and green lines at the top
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Parts
The other site that i work for has used RCA tubes, they are pricey, but they make you a deal being that you need two of them they came out of a TV that had cabinet damaged they got from best buy, so the tubes have had very little use. heres a link to there site it might be worth sending them an email.
http://servicemanuals.vstore.ca/
May 29, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Cathode ray tubes (crt) for a Sony Rear Projection TV Model# KP-65WV600.
We have a problem with the blue as well. Sometimes it is good, then it fades to green. Then it went out and back on again. Repair man said it is a bad HT Block and would cost $350 to remedy.
Mar 13, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Ekse
