Question about Car Audio & Video
I own an vauxhall omega 2.2, the central locking seems to be having mads moments. passenger door and both rear doors buttons lock, then open again. The only way i could lock drivers door was with key. Now car unlocks or locks, except drivers door where the button stays in locked position however i can still open the door!!!!? Although all the other doors are locked.Help please I don't know if this is affecting security. i.e. is the immobiliser activating? Is the actual alarm working? Because its nit going of when I open drivers door, when all the others are locked. Thanks Mags
  • 185 Answers
Have it checked out were u got sorry cant help
Posted on Apr 05, 2008
SOURCE:
Can the immobilizer or central locking be switched off in a Nissan Almeria 2001 car?
you can remove the central locking fuse , this will stop the lock/unlock constantly , the problem is usually with the drivers door lock mechanism , that is perhaps why you cant lock/unlock with the key, lock from inside vehicle and get out passenger side, that lock should work with the key until you get the lock changed on drivers door
Jun 11, 2015 | Nissan Almera Cars & Trucks
Central locking 2005 subaru liberty stopped working on 2 doors
1. Replace battery in remote
2. Replace sensor at rhf door lock (it is inside of door)
Apr 30, 2014 | Cars & Trucks
Audi central locking
Lock ALL DOORS, Disconnect the Battery... Wait 2-3 minutes and connect the battery and it should reset itself. Make sure all doors are LOCKED...
AND that you have a KEY to open the door in case it does not work.
Feb 12, 2014 | Cars & Trucks
Fault finding
check wiring for bad connection or breaks at the door pillar near the hinges ... depending on year the motor can also give trouble in the lock itself
Oct 30, 2013 | Vauxhall Cars & Trucks
After changing the battery on my VW Sharan 2005, my central locking is no longer working. The passenger door, rear doors and boot are locked by the central locking. The drivers door only works with the...
when you disconnect the battery you corrupt the cpu program in the ECM
mostly the fix is to use a fault scanner tool to reset the program
Mar 28, 2017 | Cars & Trucks
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
Central locking problem. all doors except the passenger door at rear behind driver unlock this one is permantly locked any ideas
Put your ear close to the door and activate the lock/unlock. If you hear click click there is a loose/disconected lever which is moving without activating the lock. If you hear nothing something is stuck or dead. Open door panel and clean system then check again. Might need replacing the unit in the door.
Nov 30, 2012 | Vauxhall Cars & Trucks
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
Apr 23, 2010 | 2003 Land Rover Freelander
When i press my central locking fob only 1 door opens
sequence for freelander lock unlock, to lock 1press = door lock , 2press = door dead lock , to unlock 1 press = driver door unlock, 2 press = passenger doors unlock, also rear window can be operated from fob to do so press and hold unlock button for 3 or more seconds and rear window will roll down.neat feature.hope this helps
Sep 02, 2009 | 2003 Land Rover Freelander
Car Audio & Video Logo
310 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
