On a maxtor 83200a5 3.2 gig what is the jumper settings
    Sergeant:
  • 313 Answers
Depends, are you using it as a master or a slave? If you only have one drive it should be set at master - you can always have it set cable select.
Posted on Apr 05, 2008
I need t know where to find a setting chart for ata 30 gig maxtor, for master and slave
hope u r a professional..
howevr, rememberthe master jumper is always in a vertical position along or just beside the ide cable port/pata port..
for details contact system admin/vendor....
Oct 31, 2009 | Maxtor Hard Drive
I have an old maxtor hard drive 40 gig, nad my PC couldn't recogn
just need to set the jumper so this will work as the slave
Apr 18, 2009 | Maxtor Hard Drive
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Your solution
That depends on the type of HD you have...Mine is a Maxtor 3 1/2" ATA 60 gig...On Maxtor's web site you can print the jumper settings for the type and style of the the HD you have...A side note on Maxtor's ATA HD's, the jumper setting for 'Master' on all styles would be the last VERTICAL pin setting on the LEFT.
I'm sure if you have another type (Seagate,etc.) they will have setting's on their web-site.
Don't worry if you get it wrong you won't damage the HD, it just won't work.
Hope this helps!
Jul 31, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Maxtor hardrive
If one of the jumpers shorts two pins and the other jumper is a single pin short, remove the two pin jumper. The single pin jumper should be located on the pin at the far upper right corner. should be set as a slave at that point.
May 26, 2008 | Maxtor Hard Drive
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Hard drive instalation
To slave the Maxtor you remove the jumper or jumpers
Oct 30, 2007 | Maxtor Hard Drive
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
