Question about Baby Lock Eclipse Serger
Starts good, loses steam
My baby lock serger starts great and then about 5 inches into a seam seems to lose steam and the process just grinds to a halt. Help!
  • Anonymous Apr 24, 2008
    My Babylock Serger is old (BL4-736) but runs good for a while and then chugs down to zero after about 3 minutes. I have to let it cool down and then it starts to run again for about the same amount of time. The machine does not feel hot so I don't know what is wrong. Frances D.
  • taxijim Jan 14, 2009
    Baby Lock Pro Line Model BL4-838 D starts good but slows to a stop. Sometimes after a couple of yards of stitching and sometimes quicker. It does also run again after waiting awhile. The motor is not steaming hot but is what seems normal warm. Lubrication seems to be OK. If a motor is needed where are they available for this older unit?
Had the exact same symptoms on BL4-838D machine, fixed problem by lubricating feed mechanism drive off main drive shaft. Email me at my hotmail address using name patio10h if you have more questions.
Posted on Mar 21, 2009
Your machine either needs a new motor or belt. How long has it been since you have taken it in for servicing? Sergers are work horses. They get better as they age, so take it in for servicing.
Posted on May 28, 2008
SOURCE:
My baby lock bl5260 serger starts ok but slows down and then stops
If it is a mechanical machine (not computerized), it could be seizing due to old oil that has dried. Mechanical machines, especially sergers, need frequent and thorough oiling (interior moving parts) using a good quality sewing machine oil. Avoid trying to run the macchine until you can get it serviced or the motor could be damaged.
Jan 05, 2018 | Baby Lock Sewing Machines
Baby lock serger knife disengages
it might be a good idea to have the serger check to see if there is
a timing problem
Mar 20, 2013 | Sewing Machines
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
What is a special edition eclipse serger?
Go on the Babylock web site, they have good explanations of all serger types and the differences.
Jul 11, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Jul 02, 2012 | Baby Lock Eclipse Serger
Left needle on baby lock serger "imagine" skips
Change needles if they have done a few hours. Ales use ballpoint if seaming stretch fabrics. Also you can get EL 705 needles, which have a longer scarf (groove at back) which helps with the loopers catching the needle thread. Or SUK is the stretch type with this longer scarf Also if you are using cheaper thread cones, try a better quality with smoother finish and consistent weight, this will help too. However if this doesn't resolve issue, your looper timing might need adjustment.
Oct 28, 2011 | Baby Lock Imagine
Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
May 09, 2010 | Baby Lock Evolve
Feed dogs on serger don't advance
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
Jan 18, 2009 | Baby Lock Eclipse Serger
I have a baby lock imagine machine. I'm sewing with streatch velvet, and the stitches are off the fabric, or the loopers are too loose. I tried tighting the looper thread fine tuning screw, adjusting the...
Stretch fabric is made for using the differential feed on your machine, sergers love stretchy things. Try widening the stitch you are using and turn your differential feed down one notch to allow the machine to get a good grip on the fabric, you may need to bump the differential feed up more if it still doesn't stitch nice, keep trying on a piece of scrap fabric of the same as you are using until you are happy with the stitch.Another solution is to put some lightweight tissue paper under the seams and then tear it off after you have sewn the seams, this works but will dull your blades over time.
Oct 30, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
408 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Thomas F. Schneider
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
